C63 AMG (W204) 2008 - 2015
Caliper colour change
Old Jun 2, 2015 | 08:14 AM
rickclass's Avatar
2014 C63 AMG 507 Edition
Originally Posted by -ian
Indeed you do get what you pay for. I paid $30 and 4 hours of my own time. I prepped the area in the exact way a pro paint shop would do. I used a high quality know brand paint and lacquer. I sprayed in a warm environment using the manufacturers time between coats and I'm over the moon with how it turned out.
If you think taking your car to a body shop and paying an extra $700 for the job is a better option then go ahead. It's your choice. Just like what I have done is my choice.
I will resurrect this thread in a year and post up more photos of the calipers and I'm more than confident they will look no worse that a pro job on my " $60K+ German car "
Ian...you are the king of DIY...your posts are awesome...keep up the great work
Old Jun 2, 2015 | 02:13 PM
PelicanParts.com's Avatar
SPONSOR
That looks great!
-Luccia
Old Jun 2, 2015 | 03:45 PM
Eric ATP's Avatar
2012 C63 P31 black/black
Just because you pay more does not make it better. In correct powder coat can be way worse and a complete pita to repair. Also most places use ppg or DuPont paint which is not really any better for this purpose. I have done several with sikens and they turn out good but imo it's not worth the extra expense and effort. The rattle can you used is a good product.
Very nice job also.
Old Jun 3, 2015 | 09:59 PM
solekeeper's Avatar
A V8
just bought the clear from vht.. it says engine enamel.. up to 550 degress.
will this be ok for the calipers?
Old Jun 3, 2015 | 10:40 PM
beejAMG's Avatar
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
calipers get hotter than 550 degrees. it will work but it wont hold with the heat. Ive tried them before and it didnt last long. so to answer your question, no. theres a specific clear from vht for calipers. 800 degrees if im not mistaken.
Old Jun 4, 2015 | 06:59 AM
solekeeper's Avatar
A V8
****. i looked for it, but didn't see anything more than 550 degrees.
Old Jun 4, 2015 | 07:02 AM
  #32
beejAMG's Avatar
Try to get a caliper specific clear spray can. There should be one. Otherwise you can try what you already have but know that calipers get hotter than the engine even with just normal driving. Or OP can suggest what he used. Goodluck mate!
Just checked quickly on my garage and saw my VHT caliper paint that states "can withstand up to 500 degree heat" so i reckon your clear is ok. Although i also found this clear that i used for my caliper. States "heat tested up to 1093 degrees
Old Jun 4, 2015 | 08:08 AM
  #33
solekeeper's Avatar
A V8
ok so here is exactly what i got.
-vht red "caliper paint" 900 degrees
-i also got another color for my dads car, in orange.. but it doesn't say caliper paint it says "engine enamel" up to 550 degrees
- and the "engine enamel" gloss clear up to 550 degrees.
i should just return those last two items, as they won't hold? they didn't have orange "caliper paint"
Old Jun 4, 2015 | 09:57 AM
  #34
-ian's Avatar
2012 C63 AMG
Nothing wrong with what you have bought. Exactly what I used and no issues at all with heat. Plus if your calipers are reaching more than 500 degrees C you have got more to worry about than problems with your paint !!!
Old Jun 4, 2015 | 11:18 AM
  #35
solekeeper's Avatar
A V8
well technically, we didn't use the same exact thing.
my clear only says it goes to 550. and the orange basecoat the same... ugh. idk what to do
Old Jun 4, 2015 | 01:23 PM
  #36
-ian's Avatar
2012 C63 AMG
Rears sprayed today. Same as the fronts, 3 coats of red and 3 coats of lacquer.
Old Jun 4, 2015 | 03:53 PM
  #37
Carbon Dated's Avatar
2019 GLE 63S AMG, 2009 C63
That looks really good!
Nice wheels also.
Old Jun 4, 2015 | 07:12 PM
  #38
beejAMG's Avatar
what you got should be fine mate. paint away!
Old Jun 4, 2015 | 10:17 PM
  #39
solekeeper's Avatar
A V8
ian, post 34, can on the right.. what is that? clear?
i don't see any name
Old Jun 5, 2015 | 08:27 AM
  #40
Dazzagt's Avatar
C63 AMG - PP+
Great Job Ian
Where did you get your AMG stickers for the caliper's from ?
Old Jun 5, 2015 | 09:44 AM
  #41
-ian's Avatar
2012 C63 AMG
Hiya.
This is the clear coat.
http://www.ebay.co.uk/itm/2514245608...%3AMEBIDX%3AIT
I guess you can probably get it a lot cheaper in the US.
Old Jun 5, 2015 | 09:45 AM
  #42
-ian's Avatar
2012 C63 AMG
Originally Posted by Dazzagt
Great Job Ian
Hiya.
These are the decals I used.
http://www.ebay.co.uk/itm/1112204533...%3AMEBIDX%3AIT
Old Jun 5, 2015 | 10:00 AM
  #43
Dazzagt's Avatar
C63 AMG - PP+
Cheers Bud.. your thread has even tempted me the DIY route
My red lacquer has flaked and needs re-painting and doing again.
Old Jun 5, 2015 | 11:01 AM
  #44
solekeeper's Avatar
A V8
thanks ian
Old Jun 5, 2015 | 01:12 PM
  #45
GRam's Avatar
2013 Ram 2500 Limited 2013 Harley CVO Road Glide
That looks killer, nice job!
Going to look for some copper colour caliper paint now!
Old Jun 8, 2015 | 10:10 PM
  #46
solekeeper's Avatar
A V8
did my calipers.
https://www.flickr.com/photos/127257...posted-public/
Old Jun 10, 2015 | 07:34 AM
  #47
Mort's Avatar
Looking good.
Old Jun 10, 2015 | 08:04 AM
  #48
solekeeper's Avatar
A V8
thank you sir.
Old Jun 10, 2015 | 11:02 AM
  #49
jptaylor's Avatar
W213 E63S Wagon, W204 C63 P30(RIP), WK1 Grand Cherokee SRT8(RIP)
Just my .02 from experience with this subject....
I would actually stay away from any clearcoat altogether. If you use a quality gloss aerosol paint applied as it should be that should provide MORE than enough protection for the calipers. My issue with clear has always been 2 fold....when you clear over the base you are now asking 2 different chemical concoctions to get along and stick together forever, and unless you expertly prep the base color prior to clear I believe you are just creating a potential entry point for peeling/separation to occur(think about all of the heat cycles and the fact that different parts of the caliper will expand/contract at different rates as well).....secondly, every aerosol clear I have ever worked with has a tendency to yellow over time thus changing the color appearance of the caliper itself, AND this seems to be accelerated by excess heat.
Others may have had different experience with this but in my prolly 25-30 sets of calipers this has been what I've seen
Old Jun 10, 2015 | 11:35 AM
  #50
solekeeper's Avatar
A V8
you do know this is how cars are painted right?
nothing is forever.
Prep is the most important thing. As with everything in the world.
You've done 30 sets of calipers, great. You've seen failure in every one of them?
Isolate the issue, figure out the problem, and correct it. You keep doing the same thing over and over resulting in failure, but yet you keep repeating.. makes sense.
