C63 AMG (W204) 2008 - 2015
iPE Muffler not going directly to factory tips on Black Series
Old Aug 3, 2015 | 01:41 AM
BLKM3's Avatar
G63, SLS Black Series, C63 Blackseries
I noticed a lot of guys run iPE system on their Blackseries. I recently had my exhaust system installed but noticed that the iPE muffler isn't exactly aligned with my factory AMG tips. Is this normal?
Attached Thumbnails iPE Muffler not going directly to factory tips on Black Series-img_1881.jpg   iPE Muffler not going directly to factory tips on Black Series-img_1883.jpg
Old Aug 3, 2015 | 01:48 AM
jordanaf's Avatar
507 SEDAN
I would go back to that shop. It is normal for two systems to not align correctly. It can be rectified. But, definitely shouldn't leave it like it is.
Old Aug 4, 2015 | 02:50 AM
BLKM3's Avatar
Anybody here with iPE and C63 Blackseries?
Old Aug 4, 2015 | 02:38 PM
Girard@ACGautomotive's Avatar
a car
Tons, unfortunately you are going to have to modify the outlet a little as the system wasn't designed for the black series rear bumper. Nothing a competent muffler shop can't handle.
Who installed, you're in the Bay, I can recommend a shop up there that can help you and knows all about iPE.
Old Aug 5, 2015 | 06:19 PM
Wobble64's Avatar
C63 507 with BS Body; 2008 SLK 55
I had the same issue with the Akrapovic. The tips need to be cut just at the right spot to blow into the bumper nozzle. It may not work 100% and if they blow outside the nozzle you risk getting the attachment points molten when pushing it , e.g on a track day.
I had to do 2 things finally to get it all working: cut the nozzle and bend its walls outward to catch all exhaust gases and wrap aluminum tape (Hvac tape) around to make sure all gas goes out and does not melt the point where the nozzle is bolted to the bumper.
It takes a bit of improvising, but is not difficult.
You cannot leave it as is. It will melt plastic if/when you step on it for long er.
