K-Mac Camber Plates
Sorry to revive an old thread, but are you still happy with these after a couple of years? They seem to be the only real choice for proper adjustment anyway. Looking to get a set for my track-going E63
Are they pretty easy to adjust for street use?
Also were the spacers necessary to reduce rubbing, or just for the look? Any particular brand and did you need new wheel studs?
Thanks!
Thanks!
Received 2,828 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
FYI, I have Wobble's old KMAC camber plates. They are coming out in a month and will be for sale because, like he did before me, I got KW Clubsports which already have their own.
Easy to adjust, although as Wobble said you may need to grind out the shock tower opening if you want to go max camber/caster. I set mine last season at -3deg and left it like that.
Spacers not necessary for me, but it depends on your wheel/tire combo and offset.
Good to know, thanks BLKROKT. I'm still on the factory wheels (19x9) with 265/35; going to wait until the plates are fitted before I order new ones though - I can get 275/35 AR80Rs on the wheels but not sure about the clearance
