Black series suspension adjustment
Anyone here do their own suspension adjustment on a C63 BS?
I had it in to the local dealer to soften the dampener settings and the tech went for the firmest setting. It obviously rides harder now. I read the manual and it seems to be pretty easy with a 2mm allen wrench?
I haven't done on the BS yet but there are KW suspension so yes it should be pretty straight forward to adjust them.
So, other than the 2mm hex wrench anything else need loosening first, lock nut or anything?
Also have you changed the spring height setting your car in anyway?
Like I said I haven't mess with the factory settings yet.
But since these are KW and I used to adjust height and compression/rebound on the V3 for my previous sedan process should be the same.
