C63 AMG (W204) 2008 - 2015
2010 c63 differential pinion bearing?
Old Sep 1, 2015 | 08:11 PM
sventastic82's Avatar
2010 C63 AMG RIP. 2021 Toyota Tacoma TRD Off Road, 2013 C63 coupe
Need some help identifying the correct bearings for the pinion shaft/gear.
Unfortunately the c63 differential is listed as a whole assembly for a spare part.
The individual bearings can't be identified.
I know that the axle differential bearings are the same as in the e55 and e500.
But I'm not sure if it also shares the pinion bearings.
I would appreciate some help!
Old Sep 2, 2015 | 08:00 PM
Anyone?
Old Sep 3, 2015 | 07:48 AM
Mort's Avatar
You can take it apart and take the bearing in to a bearing shop and match it up. Not ideal perhaps but you can get a replacement bearing that way.
Old Sep 21, 2015 | 07:20 PM
I got it figured out the c63 uses the same bearings as the e55, challenger and charger. Well dodge uses Mercedes differentials.
But it does not use the crush sleeve. It uses spacers which I reused and added a self made shim to it.
Here comes the best part don't order them as Mercedes parts.
I ordered them from a bearing distributor.
See pictures for bearing details.
