W205 steering wheel on W204 done
6 Attachment(s)
just to share my experience
a bit complicated work if you dont want to change your steering column just like me 1) you should find the multi-function button from a later version of CLA/A class which has up/down/left/right icon as shown in picture. not the new button which is on AMG GT/W205 C class 2) then you have to take the chip out of your original contact module in the wheel and retrofit to the W205 steering wheel's contact module box, some modification is needed to fit the pins (because the old/new contact module pins are in different places, you will understand when you have a w205 wheel) and make horn wire harness functional here is the result, with the new wrapped alcantara and rosso nappa / cf parts the car looks more refreshing now (the orignal sand/black designo nappa is good quality but definately not fitting my style) |
Looks awesome.
Can you post more pics of your car and interior? |
6 Attachment(s)
Originally Posted by AMG893
(Post 6568310)
Looks awesome.
Can you post more pics of your car and interior? some modes include: vorsteiner ff101 wheel / cf side skirt / diffuser ; akrapovic exhaust/ renntech header / mode carbon front lips / ac schnitzer (yes from bmw)hood vent insert. doors and rear seat wrapped with Lamborghini rosso nappa + alcantara; front seat replaced with recaro rs-g alcantara now it looks more unique :) |
Can you post a closer pic of the cf side skirts and diffuser?
great job! new steering goes well with the interior. just curious, how does the power seat/memory work with the recaro seats?
That looks badass
Your entire car looks incredible! More pics!!
Originally Posted by beejAMG
(Post 6568574)
your car is sick.
1 Attachment(s)
(Post 6568574)
2 Attachment(s)
Originally Posted by 507OverBiturbo
(Post 6568363)
6 Attachment(s)
Originally Posted by kb24forlife24
(Post 6568657)
Cool car. The Gruppe M is sick.
Damn that engine bay :bow:
looks superb! You have great taste.
Originally Posted by KOSMOS
(Post 6568753)
sure. i searched my photo gallery and 2 of them looks good:)
OMG, you in china, bro?
(Post 6568285)
a bit complicated work if you dont want to change your steering column just like me 1) you should find the multi-function button from a later version of CLA/A class which has up/down/left/right icon as shown in picture. not the new button which is on AMG GT/W205 C class 2) then you have to take the chip out of your original contact module in the wheel and retrofit to the W205 steering wheel's contact module box, some modification is needed to fit the pins (because the old/new contact module pins are in different places, you will understand when you have a w205 wheel) and make horn wire harness functional I have actually also bought a new type AMG steering wheel from New CLS, and took my old CLS wheel apart and new one to check the contact plates you wrote here about, believe me for similar people like me it's mission impossible to install the contact plate of older model to the new one because they are way too different. Maybe you could share some photos or some hints to how and where and what to solder or what pin to move where as you have this nice experience? Would be so great! Many people would tell you a Big Thank you. |
very badass!
+1 |
Looks awesome . I see u using some protection on the seat where u get in and out from. my driver sides all ripped i need to have it done im trying to see if i should do leather or what u have.
Awesome build! I was skeptical when I saw the AC Schnitzer hood vent, but u pulled it off nicely.
6 Attachment(s)
Originally Posted by Nerukas
(Post 6656168)
Hi, thanks for your very friendly experience, think this will be very useful and informative for other forum members who have no clue how not simple and easy is such a swap of steering wheels.
I have actually also bought a new type AMG steering wheel from New CLS, and took my old CLS wheel apart and new one to check the contact plates you wrote here about, believe me for similar people like me it's mission impossible to install the contact plate of older model to the new one because they are way too different. Maybe you could share some photos or some hints to how and where and what to solder or what pin to move where as you have this nice experience? Would be so great! Many people would tell you a Big Thank you. https://mbworld.org/forums/attachmen...1&d=1451296243 if you have the new type steering column, the only thing you need is to find the steering wheel with the right buttons as i mentioned, it is plug&play, no contact module change needed. if you are the lucky guy with old steering column as i, you have the do some DIY work. start comparing the 2 differnt contact module, (left in the image is the old/current one from the car) you can not use the old module in your W205 steering wheel due to different shell shape, the only way is to take your old contact module out from the steering wheel on your car and dissemble it, take the core chip out and put it into the shell of the contact module which is from new steering wheel https://mbworld.org/forums/attachmen...1&d=1451296243 then you have to make some cracks like i did on the contact module to allows some space for the pins on the core chips. https://mbworld.org/forums/attachmen...1&d=1451296243 the reason is simply because the old/new chips have different pins location. - the center 10 pins are the same but the pins for the gear shift down are in different place https://mbworld.org/forums/attachmen...1&d=1451296243 you can find more details in the above picture. the top left is the new chip and the right is the old one, you need to put the old one into the shell of new contact module, watch out there are also different 4pin on the edge of each chips - on your old chip the only way is to bend it and reconnect with wires, to make your horns works properly when finished, trust me- your hard work deserves (sorry i might not explain clearly since English is not my 1st language but let me know if you are not clear) https://mbworld.org/forums/attachmen...1&d=1451296243 https://mbworld.org/forums/attachmen...1&d=1451296243 |
Where did you get the carbon start/stop button from?
I had this idea that I wanted the edition 1 seats in my 2012. Anyone try this?
Hello, first thank the information provided by KOSMOS.
The second I apologize for my terrible English. And now I raise my question ..... I bought a w205 wheel (with multi-function button from a later version of CLA/A) My steering column is the old type (W204 Pre-Facelift) What steering column that I need to work the steering wheel? Could anyone give me the reference? I have discarded the option to adapt, because my current is the 4 wheel spokes, and is quite different from the 3-spoke steering wheel. A greeting. and thanks. |
