C63 AMG (W204) 2008 - 2015
How to prepare for a track day?
Old Apr 14, 2019 | 09:31 PM
  #51
BITRBO's Avatar
2001 Audi S4 Sedan (RIP) 2013 P31 W204 C63 (RIP)
Super helpful - Thanks Ryan! Yeah, I ran ST43's on my S4 when I used to track that and know exactly what you mean. Fantastic product, but that car had a StopTech BBK w/ much harder rotor rings, so I can imagine what those pads would do to a set of stock rotors : /
I'll give those PowerStop pads a look and let you know. I know the easy answer is to just get a 2nd set of pads & rotors and be done with it, but my C63 lives in So.Fla and you'd think our tracks stay open all year long, but you'd be surprised (read: disgusted) at how few fall/winter events there actually are when the weather is ideal... All the clubs usually skip Dec. & Jan. for some reason and decide to host a majority of their events when its ball soup outside, which is brutal on the equipment. I'm hesitate to make too big of an investment on brakes (and other supporting track mods) for the car considering the overheating potential w/o the 44O option.
Old Apr 14, 2019 | 10:10 PM
  #52
MBNRG's Avatar
+1 on Carbotech
A few of the the more seasoned track drivers (BLKROKT, Wobble64) run em, run em hard (on RacingBrake rotors), and have been very pleased with their performance (i believe Carbotech XP12, etc).
Hit them up for more feedback.
This thread (and others) also reference Carbotech pad performance in earlier posts, in addition to their other model pads (XP8, etc).
I have their XP10 pads (+ RB rotors), and will track with this setup soon and can provide more feedback.
XP10s were ~$500 for all 4 corners
Old Apr 15, 2019 | 02:25 AM
  #53
Ryan951s's Avatar
2009 C63
Tell you what, I still have my Powerstops and they easily have another track day or two of life left in them. If you pay for shipping, I'm happy to send them to you to test out.
PM me if you're interested
Old Apr 15, 2019 | 02:55 AM
  #54
Cozy's Avatar
C63
I tried the heat shield as detailed in “Keeping Your Cool” with some skepticism but, it really does work. It keeps the temps down enough at this time of year at least enough to stop the fans coming on even, unless you’re tooling about stationary or low speed. But, as soon as you’re moving again the temps drop rapidly and fail to rise drastically even with hard thrashings.
I’d recommend it. The real test for me will be Nurburgring this year although I imagine it’ll be fine for some semi-hard track work. It’s not the kind of track you go crazy at unless you have 500laps under your belt; too many cars, changing camber, no run off...but there is something enchanting about The Green Hell.
Old Apr 15, 2019 | 07:04 AM
  #55
DublinCLS55's Avatar
CLS55AMG 2005
Originally Posted by BITRBO
Hey guys - long-time lurker/reader.
I'm doing a track event at Daytona at the end of the month and have been slowly prepping for the event. I've sifted through this and as many other threads I can find, but can't seem to find a consistent answer:
TIA!
I did two separate events in mine with OEM pads and fluids and it was absolutely fine. One of those events was done at a twisty, technical circuit which is generally pretty hard on brakes. I continued to use the car for another two years on the road and never had to replace the front pads, though the rears did wear out.
I guess it really depends on how hard you want to push and how much compromise and cost you're prepared to tolerate. At the end of the day, it is a pretty unsuitable car for track days and to make it capable will mean a lot of change which will impact it's use on the road. Personally I would recommend you change nothing but accept that you may not be able to drive as long and aggressively as you would like. I'm sure you'll still have a great day and you could perhaps use your cool down time as an opportunity to hop into other people's cars as a passenger.
Best!
Old Apr 17, 2019 | 02:03 PM
  #56
BITRBO's Avatar
Oh, crap. I just saw this and already bought a set from Summit the other day... Oh well. If I burn through these and want more, I'll hit you up
Old Apr 17, 2019 | 02:10 PM
  #57
BITRBO's Avatar
Originally Posted by MBNRG
+1 on Carbotech
Cool, thanks!
Originally Posted by Cozy
I tried the heat shield as detailed in “Keeping Your Cool” with some skepticism but, it really does work. It keeps the temps down enough at this time of year at least enough to stop the fans coming on even, unless you’re tooling about stationary or low speed. But, as soon as you’re moving again the temps drop rapidly and fail to rise drastically even with hard thrashings...
Good to know. I'm planning to tackle that mod this weekend...
Best!
Thanks for the feedback. I see most just folks just run a set of aftermarket pads up front, but from experience, I got a set of upgraded pads for the rear to help balance the system back out and [hopefully] reduce some wear & heat on the front rotors/calipers.
