So took the AMG in to my Benz dealer
My previous '10 used to behaves better in traffic.
But to be honest I don't give a damn .
I have a 2012 with 400 miles.
I have NO tapping, knocking, shaking at idle.
My car feels like a Prius at a light. Car is solid thankfully.
ENV2 if I remember correctly you are in Atlanta. We may be able to get together to compare them if you like
I had a similar issue with a different car, and the brake booster was leaking and with pulsate the brake pedal and i would hear a faint knock with each pulse
This could be it but I had the shop foreman drive it today he said it drives well and the pulsing is common. I had a feeling it was something with brakes cause only happens when braked in gear.
Ill wait til my next oil change and bring it up. Would the brake booster throw a CEL? Is it a har part to change?
The motor is not always smooth. I will notice it more at different times. It's 100% normal for a large displacement motor. All my large displacement cars have done it. It is not a smooth silky car that's for sure.
You would throw codes if anything was really wrong with what your describing. IMO. I also agree the car behaves better when not babied around. Just the nature of the setup.
Also if your running a "tune" things will change.
