C63 AMG (W204) 2008 - 2015
Brake fluid, question...
Old Jan 17, 2016 | 06:05 PM
Wobble64's Avatar
C63 507 with BS Body; 2008 SLK 55
on a left hand drive vehicle:
1. Right rear
2. Left Rear
3. Right front
4. Left front
and: Better use a Power Bleeder as described further up in this thread, rather than pumping.
Old Jan 17, 2016 | 07:28 PM
Mort's Avatar
Bleeding the front calipers, with two bleed screws, bleed the outside screw first then the inside.
Old Jan 17, 2016 | 07:30 PM
Alex-r-1's Avatar
C63AMG Coupe 507, GL X166
Thanks guys! Yes, I have Power Bleeder.
I got the Goodridge Brake lines. And I want to install it in the coming days.
Old Jan 28, 2016 | 06:14 AM
Alex-r-1's Avatar
Tell please how torque settings AMG bleed nipples front and rear? How much Nm?
Old Jan 28, 2016 | 06:27 AM
Wobble64's Avatar
It does not take much - if I remember correctly, 10 Nm
Old Jan 28, 2016 | 11:27 AM
Alex-r-1's Avatar
Today I bought a new Bleeder Screws (my screw was rusted inside) on my dealer. Included was the instruction Brembo how to replace Bleeder Screws and was table with torque settings.
I measured my screw. Screw M10 - 20Nm torque setting. Right?!
Old Jan 28, 2016 | 12:55 PM
  #32
Wobble64's Avatar
Great - thanks for posting! Yes, if it is M10, then 17-20 Nm. I think the rear bleeders are smaller, probably M8, so they would need 7-10 NM.
Old Jan 28, 2016 | 02:23 PM
  #33
Alex-r-1's Avatar
It seemed to me that the rear screws of the same size thread.
Old Jan 28, 2016 | 05:28 PM
  #34
Alex-r-1's Avatar
I measured the rear Bleeder Screw. It is the same as the front! So, you can tighten all screws to 20 Nm.
Old Jan 28, 2016 | 06:47 PM
  #35
Wobble64's Avatar
Cool!! Thanks for doing this!
Old Dec 30, 2017 | 12:26 PM
  #36
svenpup's Avatar
2009 SL550 R230
Originally Posted by Diabolis
As Jasonoff pointed out, the biggest issue here is the fluid viscosity. All DOT 4+ aftermerket fluids are about twice as thick as the MB stuff.
I know this thread is a little old but I haven't been able to find any newer info on the MB 331.0 DOT 4+ brake fluid. Diabolis is stating that the MB stuff is half the viscosity of other DOT 4+ fluids, but I haven't seen the viscosity spec of the MB 331.0 listed anywhere so I am not sure how he can make that claim. Since the 'plus' designation doesn't actually mean anything specific, some manufactures seem to be using this as a designation for their premium (higher boiling point and/or longer service life). Additionally several manufactures are making low viscosity products that are either marked LV or class 6. If the viscosity is the hallmark of MB 331.0, why don't they spec class 6? I know many have said to just buy the MB branded stuff and be done with it, but I would like to know what they are selling for $20 per quart.
Old Dec 31, 2017 | 07:12 PM
  #37
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
The MB DOT4+ fluid was originally designed to work with the complex SBC system found on various MB cars including the SLR and Maybach. There was a note in a TSBs on the SBC system a number of years ago that indicated that the vast majority of SBC complaints and/or failures were caused by using unapproved fluid and that the MB DOT4+ fluid was engineered to maintain a very uniform low viscosity throughout the temperature range thus keeping the SBC braking components both operating withing the "calibrated" range and furthermore prolonging their life as it also had additives and conditioners specific to the materials used in the SBC braking system.
While the SBC system has now been replaced with a hydraulic one, the complex ESP systems in the current batch of cars rely on essentially the same servos and pumps that were developed for the SBC to provide very rapid automatic brake modulation, and require that specific MB fluid to operate properly and maintain their longevity. That's what they are selling for $20 a liter.
You are not going to find any more info on it (just like you won't on their specific coolant either) unless you get a job as a design engineer at MB Germany.
Old Jan 1, 2018 | 05:42 PM
  #38
Alex.currie44's Avatar
2009 SLK55 AMG. & 2022 GLA250 4Matic
The MB 331.0 DOT 4+ brake fluid is among the best on the market (the dry and wet boiling points are about the same as DOT 5) but it's nowhere near as hygrosocopic as other DOT 4+ glycol-based fluids so you can change it every two years instead of every six months.
As Jasonoff pointed out, the biggest issue here is the fluid viscosity. All DOT 4+ aftermerket fluids are about twice as thick as the MB stuff. I think the conventional SBC system was dropped in the late 2000s as MB now accomplishes the advantages of the SBC system using some clever programming in the ESP, but for proper operation of those you need the thinner fluid.
Yes, Castrol SRF is about as good as brake fluids get FOR TRACK USE ONLY, but unless you flush it every three months and never drive your car in the winter, I wouldn't use it in a daily driver car.
Silicone-based DOT 5 fluid is a big no-no in systems not designed for it as it will destroy pretty m,uch everythign, so if you're absolutely determiend to use something aftermarket, do what Jasonoff did and use the DOT 5.1 fluid... except that there's really no reason to use it over the OEM MB DOT 4+ fluid as their characteristics are the same and the OEM fluid won't bugger up your ABS pump, harden your seals or make the hard brake lines corrode from the inside.
If it ain't broke - or doesn't need upgrading as is clearly the case here - don't fix it.
They annouced SBC would end in Decemmber 2005. It was only used on 2003 to 2006 on W211 E class and while I had no issues with it you did have to learn how to bring the car to a smooth stop without launching your passengers. Software was constantly being updated for all the time I had that car which was 5 yr. It was also used on the SLR, Maybacj and 2003-2006 CLS. I always so this as something they did because they could vs. because it was needed. It was supposed to sense issues and allegedly applied more pressure in a panic stop than a driver could but it was more a pain in the butt.
Old Jan 13, 2018 | 09:31 PM
  #39
m3driver's Avatar
09 C63, 04 CTS-V (just sold), 06 325, 15 500e, 96 NPR, 05 C172
Originally Posted by Jasonoff
I use a motive. Have bled a few times now. Soft-ish pedal when it's running. Hard as f__k if it's not.
EDIT: I also modified mine to take in an air line.
Nice to see the product in use. Also like the mod - but I hope you are using CDA on the mod, else wise you'll be contaminating that nice clean fluid :-(
Anyway I'm actually one of the owners of Motive Products. If anyone needs a bleeder or anything else we manufacturer send me an email and we'll give you a discount. Cheers
Marco
Old Jan 14, 2018 | 09:03 AM
  #40
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Marco
Good point but doesn't the hand pump also contaminate the fluid when pressurizing the bottle?
Even if the compressed air was full of moisture, wouldn't the fluid from the bottom of the bottle, in theory, be unaffected?
Old Jan 14, 2018 | 12:42 PM
  #41
RLebwohl's Avatar
2017 SQ5, 2012 C63 P31, 2001 Boxter S
I've had my 2012 C63 for a few months now and it will be going to the track 3-4 this year starting in April. This will be my first time taking a AMG to the track and can't freaking wait.
How does the OEM brake fluid handle the track? And the same goes for the brake lines? I've used Motul
in all my other cars I've taken to the track, will this also be good for the C63? I am a more advanced driver for what it's worth and the car is completely stock with the performance package.
Thanks for any advise!
Old Jan 14, 2018 | 01:21 PM
  #42
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
OEM brake fluid and lines are going to be ok. So is Motul. What you should really focus on are new brake pads because the OEM pads are rubbish, borderline dangerous for use on track.
Old Jan 14, 2018 | 04:52 PM
  #43
Diabolis's Avatar
... and finding a 44O package because with a 2012 you'll be able to do about five laps before the oil overheats and the car goes into limp mode.
Old Jan 14, 2018 | 05:28 PM
  #44
BLKROKT's Avatar
With the addition of a radiator blockoff plate you can be good up until it’s gets to about 80F out. But anything hotter than that then, yeah, you’re screwed.
Old Jan 14, 2018 | 06:00 PM
  #45
Tex5's Avatar
CLK 63 AMG Black Series, A45 AMG
For track use,IMHO basics are :
- stainless brake lines
- high performance brake fluid (Motul RBF 600 or 660 is good, Castrol SRF is probably better but really expensive) to change twice a year at least
- track (higher friction coefficient) brake pads
Old Jan 15, 2018 | 04:12 AM
  #46
m3driver's Avatar
Good question - the hand pump doesn't compress the ambient air enough to really cause a problem. But I'm assuming you're using a typical air compressor that pressurizes a tank to 100psi or more and then you are regulating the air down to 15psi. It's the compression to 100psi+ that is the issue. Have you ever drained your air compressor tank after use? I bet you get some water coming out of the drain (and rust).
https://www.thecompressedairblog.com...ressed-air-wet
Air / water separators are pretty cheap and also will help keep your air tools in better shape.
Amazon Amazon
cheers
Marco
Old Jan 16, 2018 | 09:58 AM
  #47
RLebwohl's Avatar
Thanks. I think I am going to get a set of the Ferodo DS2500 pads for the front. I have had really good luck with them in previous cars, they are good on the street too.
Do these things really over heat after a short amount of time on the track??
Old Jan 16, 2018 | 11:56 AM
  #48
Diabolis's Avatar
Unfortunately yes. Even when the ambient temperatures are low enough so that the car doesn't go into full limp mode, the oil temperature without the 44O package gets high enough (>120C) that the oil can no longer provide adequate protection to the engine, which then leads to other problems down the line.
Old Jan 16, 2018 | 12:06 PM
  #49
RLebwohl's Avatar
Excuse the newb question, but what is the 440 package?
Old Jan 16, 2018 | 12:14 PM
  #50
xEryx's Avatar
2019 E63s AMG
Cooling package 440 for C 63 AMG Results of the further development from inter alia the „F1 AMG Medical Cars” have led to the development of an enhanced cooling system for the C 63 AMG. In order to allow an even better cooling, high-performance coolers are applied in combination with an optimized air path which allow a reduction of the engine oil temperature while driving. Therefore, these measures can also serve the purpose of an optimized cooling of the engine while operating in the outer limit.
The cooling package includes the following changes:
• larger front oil cooler lying
• larger wheel arch cooler
• custom air guides
• Larger air intakes in the underbody paneling and wheel arch right
• Custom oil lines for engine and gearbox oil
