Front Rotor Rings
EDIT: it might be worth pulling a back rotor too. I know they aren't rings on the back, but at least the rotors would all match if rings and rear rotors came from the same place. Doesn't help me as apparently the C63 rear rotors are different than my rear rotors, but probably be cheap and matching.
Yes, that is excellent news. My understanding is the new rotor width is 36mm as yours is likely worn a bit. However I don't know if they can do the measurements with the rotor bolted together. I could call Monday and confirm as I don't know if you want them unbolting your rotor. I should probably call or someone should call and make sure they handle walk ins for measurements.
#34
#35
The RB front and rear combo kit is the cheaper than Coleman rotors after adding hardware and labor to assemble them.
RB two piece rotors have the price you are looking for with track proven durability with wide coverage that no other brake company can even come close.
http://www.racingbrake.com/Mercedes-.../mb-irk-18.htm
#36
