Wavetrac Diff
So I require 1 of each.
I've ordered the 2 seals, sealing compound and the 2 bearings from my dealer. No stock in South Africa, so they will get it from Germany.
So the parts should arrive at around the same time as the Wavetrac from the States.
Looking forward to getting a proper diff in the car.
I tried to drift around a circle the other day, and it doesn't work so well when only the inside wheel spins.
2010 C63
My quoted time was 6 hours and from memory the final invoice was in that range. Apparently it is a time consuming exercise because there is so much going on under the rear. Nothing like the simple swapping out of the the centre in an old Chev or Ford.
