DIY Front Brakes - Pads & Rotors
Hey guys. I plan on replacing my pads and rotors but have a few questions. I have the OEM parts from my dealer, was only $590 total. I've never done this on a Mercedes before, but have on my BMW 335.
I've been looking at this thread but it doesn't touch on the Rotor replacement: https://mbworld.org/forums/c63-amg-w...rake-pads.html Few questions... Is the caliper difficult to remove to get to the rotor? I'm guessing a few bolts on the back? Do I need to replace the sensor if it has not been set off yet? Do I need to put an anti-squeal compound on the back of the new pads? THANK YOU ALL! |
a=no
b=yes, but cheapos don't c=no, read the instructions |
Originally Posted by Plutoe
(Post 6827866)
a=no
b=yes, but cheapos don't c=no, read the instructions I am interested in a more detail response also. |
Originally Posted by s.e.a.n.
(Post 6827928)
Wow that explains a lot.
I am interested in a more detail response also. Take off the wheel. Remove brake pads (one bolt for the front, 2 pins and a spring retainer for all). Remove caliper (2 bolts) Remove rotor set screw (1 torx bolt) Remove rotor. Reverse. There isn't any more to it than that. |
Originally Posted by BLKROKT
(Post 6827959)
Not sure how much more detailed it can get? :confused:
Why are some saying no to putting anti-squeal on the back of the pads (between the back of the new pads and the backing plate)?
Originally Posted by jmueller
(Post 6828042)
Originally Posted by AMG3.2
Just did mine. I put anti-squeal so curious to this as well.
Well my factory installed pads (still on originals) are squealing like a pig, so when I put new OEM pads in next weekend, I think I will try some anti-squeal.
