C63 AMG (W204) 2008 - 2015
Are you guys burning any oil/adding oil?
Old Oct 16, 2017 | 06:11 PM
  #51
NotABaller's Avatar
2012 C63, 2014 E550
Originally Posted by Jasonoff
It's not ideal. Get a catch can.
Maybe you're getting excessive blow by on cold starts? Any blue smoke when you first fire it up?
Thanks for the reply. Ive been doing a lot of reading and you posted helpful stuff - thanks for that too.
No blue smoke from what I've seen and from what my gf reported to me. She also says car doesnt smoke when pulling away (after I drop her off or something).
However, someone told me on the highway that I was burning oil, there was blue smoke he said. At that time, I was going downhill in gear so the revs were held at 3-4k. Then when I hammer the throttle it releases blue smoke. This would make sense and match my own observations too. I notice the smell more when downshifting into high revs or engine braking. I think oil is getting sucked through when throttle is closed at high RPM. Of course its not good, I'm just not sure whether this amount is tolerable :/
And I'm also not sure what % of my oil burned is caused by this vs oil consumed in cold starts with M1 0w40. And this seems to have started and gotten worse with the headers installed at beginning of September, so I'm not sure if this is the 200 cell "race cats" getting fried, or an existing mechanical fault getting worse.
Old Oct 16, 2017 | 06:55 PM
  #52
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Get a catch can. High rpm with the throttle plate closed will draw oil through the PCV. It's not in the best location.
Your IM probably looks nasty...
