C63 AMG (W204) 2008 - 2015
Peeling roof moulding strips
Old Sep 7, 2016 | 01:37 AM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
Anyone have any luck DIY refinishing peeling roof strips? Don't flame me, but I was curious if I could just clean off the peeling clear coat and then reclearcoat them. Either that or just buy new ones, they aren't expensive and I've actually reinstalled them before on my w202...
Old Sep 7, 2016 | 03:00 AM
GRP's Avatar
GRP
2010 C63 and 2018 GLC63s
I was pondering peeling off the clear coat (no idea if they will clean up easily - suspect I could clean them on the car with a powered pressure spray) and then vinyl wrapping them.
When I mentioned the peeling to my dealer the answer was the standard BS we have never heard of that before and in any event the trim is not covered by warranty.
Wrecking yard for a cheap set?
Old Sep 7, 2016 | 09:14 AM
Actually another member posted he found them online for about $100 each.
Old Sep 7, 2016 | 12:25 PM
SaphGreyC63's Avatar
2012 C63 AMG Sedan
I noticed mine peeling. At first I thought it was a clear film I forgot to take off. Turns out I was wrong. Kind of bad since the car only has about 25,000 miles on it (its been 4 years though).
Anyway, I was going to get all my chrome trim re-wrapped this weekend from matte black to gloss black and I am having them wrap the roof rails gloss black on top of the trim since I never use the roof system.
Old Sep 8, 2016 | 12:27 PM
akmatic63's Avatar
10 C63, 06 S65, 14 ML350, 95 S500
I knew someone who had them refinished only to peel again a few months later. I never had this issue yet, but I would probably look into wrapping it maybe?
Old Sep 8, 2016 | 05:42 PM
dustinian's Avatar
2012 C63
This is starting to peel on my girlfriend's c63 - anyone know the replacement part number and/or where to get the parts for a decent price?
Old Sep 8, 2016 | 08:50 PM
mcsvt's Avatar
08 C63
Noticed mine where pealing today too, I guess hoping it was just a plastic film left on was too good to be true.
Old Sep 9, 2016 | 12:18 AM
One work around would be to just spray them flat black and skip the clear altogether.
Old Sep 9, 2016 | 12:19 AM
Someone on here said he wrapped them and didn't like the results.
Old Sep 9, 2016 | 10:11 AM
ENV²'s Avatar
2001 Porsche 911 Turbo (heavily modified)
How do you remove those strips?
Im thinking to just plastidip mine and be done with it.
Old Sep 9, 2016 | 10:48 AM
INS1GNIA's Avatar
'13 C63 AMG P31
I've heard they just pull off/out. Just start at one end and work to the other.
Old Sep 9, 2016 | 11:52 AM
They do just pull out, you may break some clips but they aren't expensive.
Old Sep 9, 2016 | 12:17 PM
1Lop2K5C's Avatar
C63
I thought I was the only one with this issue. Quality issue for the W204? Does anyone know the part number for left and right? Thanks
Old Sep 9, 2016 | 02:00 PM
C SEXY 3's Avatar
2006 E350 (SOLD), 2010 C63 AMG
Ugh, just started to happen on the driver side (you know so now it affects me) going to look for a solution also. I would love to color match those to the color of the car, but they could never get the white color perfect
Old Sep 9, 2016 | 02:02 PM
C SEXY 3's Avatar
Oops wrong part!
Old Sep 9, 2016 | 02:39 PM
2012 C63 AMG Sedan
I'm getting mine wrapped tomorrow, I will let you guys know how it comes out
Old Sep 9, 2016 | 04:22 PM
gmaschine's Avatar
W463
Did a tester on my passenger side wrapped with Matte Black vinyl and I hated it.
If you are going to wrap it. You should try to color match your factory paint with gloss vinyl. Looks so much better.
I just ordered 2 new ones. I plan on keeping these nice and prevent them from peeling again, the factory clear coat on these is extremely thin and weak! The plastic trim somehow absorbs a ton of heat and cooks itself.
I applied some 303 Aerospace Protectant and waxed over it. So far so good.
http://www.oemercedesbenzparts.com
#9040 is factory gloss black painted
ROOF MOLDING 204-690-76-82-9040 1 $111.60
ROOF MOLDING 204-690-75-82-9040 1 $111.60
Old Sep 9, 2016 | 04:30 PM
C SEXY 3's Avatar
Much more reasonable.
Old Sep 9, 2016 | 04:36 PM
bhamg's Avatar
C63 AMG
That's shocking. Treating it with something like this will most likely permanently eliminate the problem.
http://www.autopia-carcare.com/opti-coat.html#reviews
Old Sep 10, 2016 | 12:08 AM
QWKSNKE's Avatar
09 Carrera S, , 03 F250 CC FX4
Mine have started peeling a few months ago but it doesn't spread more than inch past the roof rack mounts.
Some in carbon fiber might look good
Old Sep 17, 2016 | 11:39 PM
2012 C63 AMG Sedan
Ok so as promised here are the pic (sorry didn't get before ones).
My peeling was roughly at the beginning stages. Just the driver's side was showing peel, passenger side nothing yet.
I have attached three pics.
Pic #1
Within the circle you can see toward the right side (side closest to roof) that it was peeling underneath. These pictures are literally inches away. My installer told me that it would show through, but he put a test strip on and I told him its fine go ahead, its only going to peel and get worse if I don't stop it now.
Pic #2 (self expalnatory)
Pic #3
This pic is from a normal height of looking at the car. As you can see, you literally cant tell.
I don't know how much this cost by itself, but my guy is awesome, probably charged me around $40 to do both sides in gloss black and is worth it since it wont peel anymore. He also did my window trim and trunk strip. I also added a gloss black spoiler I was able to pick up for free. Here's some pics.
Trunk
Side windows
And last pic is of the front, Grill is plastidipped, LED and front lip are wrapped in a (to me) very nice carbon fiber wrap. Looks damn close to the real thing. PS, I recently had a fix it ticket for the front plate, so I just but some nuts and bolts to hold it in place, got it signed off, plates are coming off again.
Old Sep 18, 2016 | 01:33 AM
Looks good to me. How long do you suppose the wrap will last? I'm thinking of doing the same, including the trim and trunk strip. Btw can anyone recommend a wrap shop on Los Angeles?
Old Sep 18, 2016 | 01:36 AM
Also, I would think they could wrap the roof strips and then just cut out the little openings, no?
Old Sep 18, 2016 | 03:35 AM
2012 C63 AMG Sedan
I actually had the windows and trunk strip re-wrapped. The original was matte black, I wanted gloss black. I have had the wrap on for 4 years now, and it had held up. It did not even remotely need changing, still looked as good as the first day I did it. I expect it to last.
Also, my guy is in Los Angeles area. Out in Alhambra actually. PM me if you want details. He also re-plastidipped my trunk star emblem because I did a really poor job on it.
Yes, they could cut it out easily, but I asked them not to because it overall looks cleaner and most of the peeling was occurring around the roof rack openings. Also, I never have used my roof rack and in all honesty never plan on using them so I told them to wrap directly over it.
Old Apr 5, 2018 | 10:12 PM
sakaweme's Avatar
2009 c300 W204
Wrapping
Ok, I'm not so up on all these terms, but what is wrapping? The roof trim on my c300 is peeling and I would love to get it fixed.
