C63 AMG (W204) 2008 - 2015
Ball shaft at front of intake question
Old Sep 22, 2016 | 02:54 PM
shaun.barnard's Avatar
2012 C63 AMG Coupe
I would do a search but I don't know what it is and what it does but I have a shaft with a ball clip that clips onto a ball but the plastic part is worn and comes loose. I just want to know what it is and how it works and what it effects if not hooked in.
Position of ball arm thingy
A closer shot.
My assistant mechanic was not much help either. Kept saying it was a fuse or something
Old Sep 22, 2016 | 02:58 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Maybe a hairball issues?
Old Sep 22, 2016 | 03:12 PM
2012 C63 AMG Coupe
Maybe
Old Sep 22, 2016 | 03:52 PM
Top Answer: 1
That thing is a vacuum operated valve inside the manifold that helps throttle response at different RPM's I believe, seems to be called a vacuum cell. Hopefully it is the little arm that is the issue, not the part on the intake as that doesn't appear to be separate.
This diagram may help http://mbfans.me/EN/mercedes/c/1/a/M...anifold/sg/030
Old Sep 22, 2016 | 04:36 PM
deadlyvt's Avatar
2010 C63 AMG
It switches the intake runners from long to short
which helps maximize engine torque/power throughout the rpm range
Old Sep 23, 2016 | 08:15 AM
2012 C63 AMG Coupe
Ok so it has a bit of an effect on performance and fuel consumption then.
Old Sep 23, 2016 | 08:18 AM
2012 C63 AMG Coupe
Thanks for this. It will come in handy with part numbers.
Old Sep 25, 2016 | 01:27 PM
2012 C63 AMG Coupe
Update: Went for a drive yesterday and CEL came on. Checked the faults on my Torque app:
Cleared the fault codes and CEL stayed on then re tested for faults and same codes popped up. Went home, put a cable tie on the shaft to secure it to the ball, reset the faults and CEL went off. Retested afterwards and no fault codes. Went for a drive today and retested again because CEL does not always come on if there's faults I have noticed in the past with other cars as well but no faults found.
