C63 AMG (W204) 2008 - 2015
Part numbers for Exhaust Clamps and Seals
Old Nov 6, 2016 | 02:48 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
I am about to install Mikes Power Pipe, but being in the NorthEast, everything is pretty rusty and frozen, so going to probably need to cut them off, but either way want to get the clamps and gaskets.
Online diagram of exhaust parts seems to conveniently leave out only the clamps and gaskets for some reason.
Up on the lift, I got the following part numbers for the clamps.
Clamps part numbers are:
A0004901441 Behind Cat Drivers Side
A0004901541 Behind Cat Passenger Side
A0004901441 In Front of Cat to Header Pipe
A2214920081 is Cat Converter Left Sealing Ring, Looks like only the clamp that ends in 1541 uses a seal, the other 2 just metal on metal.
Just wanted to document as I could not find the info easily searching around.
Found this parts diagram eventually on an italian site that seems to list them parts.
http://www.iauto.lt/mercedes-benz/Ca...oups_ID=529173
Rob
Old Nov 6, 2016 | 05:34 PM
Mort's Avatar
I found with rusty clamps on mine all I had to do was give them a good twist and the bolts snapped in two making it easy to get the clamps off. You will need new ones as the nut is a barrel shape and I don't think you will find one off the shelf. Nice SS clamps but nuts and bolts that rust together, go figure. GL with the install.
Old Nov 6, 2016 | 06:31 PM
Top Answer: 1
Thanks and you are exactly right, the clamps are nice, the bolts and nuts are very rusty and pretty sure they will break, so ordered all new and the one seal, FCPEuro stocks all the MB parts and is only one state away, so 85 bucks and a couple days and will be ready to give it a go!
Old Nov 8, 2016 | 10:24 AM
FCPEuro's Avatar
Former Vendor of MBWorld
Mercedes
Thanks for giving us a shot, also if you guys need diagrams you can use our diagram site oempartsindex.com
We also have a banner that pops up after you enter your Mercedes, the site is a work in progress but should be helpful.
Old Nov 8, 2016 | 12:21 PM
Top Answer: 1
No problem, always been happy with you guys from way back when I had an old Volvo to keep going - service pricing and the great guarantee and return policy keeps me coming back and the fact that you are hear in the northeast!
Rob
