Vancouver c63 exhaust
Hey guys,
im on the fence on which section of the exhaust to delete. YouTube have enough clips but I want to see if anyone is in the Vancouver BC area, so I can get real life example. Right now it is between removing the cats vs just removing the resonator (with straight)
Car: 13 c63 coupe
thanks
Car: 13 c63 coupe
thanks
I can't help you hear it locally, but if you like how your car sounds, just do the secondary cat delete and it will still sound the same just 30% louder, resonator delete will alter the sound a bit.
So gut the sec cat and replace with straights will give me the same sound but louder? Cheers
I am in Vancouver, with a secondary cat delete, but I can confirm it sounds the same just louder. You can pm me if you want.
Yes just straights, search Mikes Power Pipe if you want a bolt on option, he makes straights or an H pipe which is a very little bit less loud than the straights, or just find a good muffler shop to make a set.
