Agency Power headers: Vibration in steering wheel when cornering left on throttle
All front end suspension, tires, brakes... checked. when they inspected the steering column, they told me due to the after market headers and the tight clearance between steering column, when engine is under load it shifts slightly and while turning left the one exhaust runner actually makes enough contact with column to cause the vibration in steering wheel.
Just wanted to see if anyone else here has experienced this problem. Read a post a while back about issues when having to pull the steering column from spline. But discussed with mech. that did the exhaust install and he said he didn't have to do that.
Few attempts to inquire to A.P. about this issue with zero response
Still happy with performance(other then vibration) and sound. Even the overall quality is decent. BUT 3k spent on headers that don't fit and no customer support does not sit well with me. I'll post some picks. Not the best but should give an idea if this is in fact the cause. Thoughts?
this pic was taken while right after headers installed circled runner and steering column
This was taken by the service tech. at the dealership. Quality not as good but looks to be a bit of scoring between the 2
lick my wounds and do it right. Or just heat the one runner up and smash it in a bit
