C63 AMG (W204) 2008 - 2015
Camshaft Noise on start up
Old Mar 25, 2017 | 01:02 AM
FEZZ00's Avatar
W204 C63 AMG
H
Hi guys i hope someone can help me i have this camshaft adjuster noise on start up , i have consulted a few people some claiming its a stretched chain which i kinda differ on the noise started after i did an oil change and its starting to irritate me a but , do these adjusters become loose due to load or its a normal wear and tear item , my car is 2008 with 109k on the clock which is baby mileage for. 9 year old car
my car is modified running a 125 shot progressive nitrous system
, Custom Headers , Full exhaust . Heat spacers , filters stage 3 software
any suggestion would be welcome on how to remedy the situation
Old Mar 25, 2017 | 09:05 AM
Celicasaur's Avatar
W212 - E63 AMG
From what I've read, most people try 5W 40 oil to help remedy either tappet or adjuster sounds. But it's only a temp fix tbh. Only way around it is to replace and at your miles, it's probably about right tbh. I might do mine next year.
Keep us posted if you do replace them. Car should runner better with them replaced too
Old Mar 25, 2017 | 09:09 AM
skratch77's Avatar
2005 E55
if your car is having cam codes you might need new adjusters
Old Mar 25, 2017 | 10:41 AM
AMGonFire's Avatar
2012 c63 AMG, 2011 GLK 350, 2019 GLS 450
Yea if it's showing codes they are probably bad. Do you have a check engine light?
Old Mar 25, 2017 | 12:42 PM
FEZZ00's Avatar
W204 C63 AMG
No engine light just that code that came up light came up once then the following day was gone
Old Mar 25, 2017 | 02:09 PM
FEZZ00's Avatar
W204 C63 AMG
no issue with car it runs strong still , i am not sure which adjusters the top one or the exhaust ones
Old Mar 26, 2017 | 05:54 PM
layzie12g's Avatar
2008 Mercedes Benz E63
There is alot of info on this. If its the harsh grinding noise on start up its the adjusters. If you have a ticking noise it is cams and lifters.
You can get all of it done for between 8 and 10k. Then you had might as well do head bolts while you are at it.
Old Mar 27, 2017 | 01:12 PM
tompen2405's Avatar
C63 AMG
It is easy to check which adjuster
Also look this video:
Old Mar 29, 2017 | 10:42 AM
FEZZ00's Avatar
W204 C63 AMG
Thanks but can i drive the car with that start up rattle though?
Old Mar 29, 2017 | 10:54 AM
AMGonFire's Avatar
I'll tell you this iv had the rattle on occasional startups for 2 plus years. Had adjusters replaced still had the noise. Told it was normal by multiple dealers. Debatable probably. I can tell you I have not had any issues driving it. Pulls Hard runs great.
Old Mar 29, 2017 | 12:34 PM
FEZZ00's Avatar
W204 C63 AMG
The main cause of this issue is oil starvation on the intake camshafts personally i dont have much faith in the factory 5w 40 more so on a high performance engine also once u modify it u need to up your oil since camshafts and adjusters rattle due to the oil not lubricating enough on the intake camshafts but lubricate well on the exhaust side as the oil drain back my question therefore is if i change to 10w 60 could i possibly cure the rattle as this will mean better lubrication as the jets that spray on the intake will spray a slighly better , heavier oil
just a q...
Old Mar 29, 2017 | 03:51 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Right. Great idea! Just run a straight 40W and it'll rattle even less.
Old Mar 29, 2017 | 04:11 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
when they think its legit
Old Mar 29, 2017 | 04:31 PM
FEZZ00's Avatar
W204 C63 AMG
I was asking the question......🙄Read because we know that its cause by poor lubrication therefore do we need to change the oil
Old Mar 29, 2017 | 06:05 PM
Mort's Avatar
According to MB the M156 can use Spec 229.5 oil in 0W40 or 5W40 only.
Old Mar 29, 2017 | 11:57 PM
roadtalontsi's Avatar
10 C six trizzle
i dont think most of these people realize the noise you are talking about. The adjusters make a rattling/ratcheting noise at cold start for 0-3 seconds and go away. The lifter noise is a constant rpm based ticking that will slowly work itself out in a few seconds to a few minutes once the the lifter pumps up. Both are caused by oil pressure bleed down. Yes you are ok to drive the car, however its a problem and the sooner you get it fixed the better.
Old Mar 30, 2017 | 09:23 AM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
If the noise is constant cold & warm this might mean the camshaft is hitting/eating thru the lifters. I've seen this issue on early m156s, don't know if it's applicable to 08 and later engines.
Old Mar 30, 2017 | 12:26 PM
PACougar's Avatar
1000Hp Diesel Trucks, 2019 E63s
The loud startup noise from the Adjusters is nothing to worry about, if you don't like the noise, put new Adjuster in but either way it's not going to effect anything. The loud continuous noise from the Lifter Buckets and Cams, that's a real problem.
