strange, transmission in C won't upshift. at times
i could be wrong since this is just from memory...
but if you're driving in C or S mode and you happen to tap on the downshift paddle or move the shifter to the left, then you car dash should say something like D1, D2, D3, etc... this means you're still in automatic mode but you just changed the top gear your car will shift to... if it says D4 on your dash, then your car will not shift beyond 4th gear unless you hit redline... if you're in this particular mode and you want to get out, just keep tapping on upshift until your dash shows the C or S again... or you can also just hold onto the upshift and it will quickly get out of it... or you can press the C,S,M button a few times...
if you want to really shift manually, then you should stay in M mode... but you would have to up shift each time... M mode will NOT automatically shift you to the next higher gear when you hit redline...
