C63 AMG (W204) 2008 - 2015
Odd sounds from wheels after changing bolts
Old Apr 18, 2017 | 04:53 PM
saulgoodman's Avatar
2013 C63 AMG Sedan P31
Hey all,
Newbie alert, I just got new mcguard locking screws for my car and I installed them without lifting the car (quickly removed one bolt from each wheel and replaced with locking bolt - also checked that all other bolts were properly secure).
After this I drove the car 15 feet and heard weird noises from the wheels every few feet, clonks and what not.
I immediately parked the car and lifted up each corner of the car and loosened every bolt and tightened the wheels back on again appropriately.
After this I drove the car another 15 feet and the same sounds are present; I parked the car up now, because the sounds were worrying.
Question is; is this a normal sound of the wheels setting in / will the sound be gone after driving further than 15-20 feet?
Thanks in advance!
Old Apr 18, 2017 | 04:57 PM
Thrilla's Avatar
Veteran: Army
2014 C63 AMG 507 sedan
Originally Posted by saulgoodman
Hey all,
Thanks in advance!
If the rear bolts are longer than OEM, chances are they're rubbing the parking brake and causing that noise. Correct the length and it should fix the issue.
Old Apr 18, 2017 | 05:06 PM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
^^ this.. Make sure the new bolts are 27mm or else u will hear a clicking sound in the rear.
Old Apr 18, 2017 | 05:36 PM
Thanks Thrilla and Roswell, that solved my problem. I feel like an idiot, assumed they were the correct lenght as they were listed as W204 C63 bolts..
Cheers fellas!
Old Apr 19, 2017 | 10:14 AM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
They may be 27mm and still rub. There's only about 2-3mm of clearance between the OEM bolts and the parking brake assembly in the rear hubs. I see nice HREs on your car pic sig... even with 27mm length bolts, if your aftermarket wheels have a very sligltly thinner mounting pad, the rear bolts could still end up hitting the e-brake assembly. Glad you sorted it out.
