C63 AMG (W204) 2008 - 2015
Asking fitment and tire size. Help.
Old Apr 25, 2017 | 04:03 PM
brian63's Avatar
C63 2010 (W204) - black
Hi Guys,
I'm using MB C63 2009 and I already got HnR coilovers installed. I bought a set of Zito ZF01 wheels in 19x9 and 19x10. I plan to buy Michelin PSS or Nitto. I want a good fitment so it will looks proper and good. What tire size should I use? These are my thoughts;
Front: 245/35/19
Rear : 265/30/19 or 275/30/19
Will I rub if I use 275 in the back?
Thankyou all. Appreciated!
Old Apr 25, 2017 | 04:07 PM
RevisionCuda's Avatar
W213 E63S Wagon
From stickies:
OEM wheel sizes and offsets (same for 18” and 19”)
- Front is 8” width with +45 offset, rear is 9” with +54 offset
- C63 hub center is 66.6mm
- Bolt circle is 5 x 112 mm (corrected)
OEM tire sizes:
- 18's stock is 235/40-18 front and 255/35-18 rear.
- 19's stock is 235/35-19 front and 255/30-19 rear.
Wider Tires:
With stock wheel sizes and offsets and stock ride height, 10 mm wider tires will generally fit without problems:
- 18's at 245/40-18 front and 265/35-18 rear.
- 19's at 245/35-19 front and 265/30-19 rear.
Some brands of 255 mm fronts and 275 mm rears MAY work but fitment may require different wheel offsets, and lowered cars may rub. Wider wheels are recommended. Check forums for feedback on specific tires and fitments.
Old Apr 25, 2017 | 04:48 PM
Mort's Avatar
Post up the offsets of the Zitos front and rear. Need those to pick tire sizes.
