C63 AMG (W204) 2008 - 2015
Rear Center Seatbelt Stuck
Old Jul 5, 2017 | 02:09 PM
Dogtag114's Avatar
2009 c63
My rear center seat belt will not release at all. (2009 sedan)
I did lean the seat forward to relieve some tension and try to release, but it won't budge.
Any ideas how to resolve or remove to reset somehow?
Thanks.
Old Jul 6, 2017 | 01:09 AM
Alex.currie44's Avatar
2009 SLK55 AMG. & 2022 GLA250 4Matic
Thanks.
Do you mean you cannot pull it out or it will not retract?
Old Jul 6, 2017 | 07:32 AM
Dogtag114's Avatar
2009 c63
It will not pull out... at all
Old Jul 29, 2018 | 11:50 AM
Dogtag114's Avatar
2009 c63
Bump... only think in my car I can not seem to fix... never use it but for still want to fix.
Is there a way I can remove and reset it somehow?
Old Jul 29, 2018 | 04:11 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
I have seen many posts on it happening on the ml350 seats think they all are similar maybe search on that. It is a ***** to get to it I will tell you that the seat is basically staples together and has some hidden fasteners to get the back off to get to it.
here is an example https://www.google.com/amp/s/www.ben...n.html%3famp=1
looks like the trick is pop the seat bottom, no tools needed and then remove torx bolt holding belt to floor of car and then you can release the tension and pull it out. Looks like the stop button sometimes comes off and then it goes in too far.
Old Aug 4, 2018 | 12:48 PM
Dogtag114's Avatar
2009 c63
It is actually just the seatbelt mechanism in the top of the seat that is stuck.
i can lean the seat forward to release the tension on the belt, but it just won’t come out.
anyone know how to access this mechanism to rest or release it?
