How to Cancel Immediate Upshifts when Switching Into S+ Mode from M @ High RPM
If your racing through the gears in C then I wouldnt switch to S. Same for switching to S+ during WOT from S. Tranny shift patters/points change.
Going into M from S+ will leave it in whatever gear your already in.
Really no big thing IMO....as long as your cruising in a steady gear during the switch between modes.
I daily drive my car 50 miles a day. Ill drive in C from my driveway until I get to the highway (less then a mile away) then switch to S or S+ for the highway drive to work once Im in 7th gear and crusing.
I have tested this a lot over the past couple years
My tuner couple of months ago while he was reading my data says to me do you use M Mode while racing and I say yes all the time he tells me I'm a idiot tells me to go do another pass in S Mode Bang PB I was shocked
But guys with upped RPM limit not a good idea to use S Mode your gearbox doesn't apply enough line pressure for upped RPM limit so stay with Manuel Mode
Just my 2c
Yes, the trans learns when in one of the AUTO modes. What it learns is how to select shift points based on your driving style. And quite obviously, it doesn't need to learn how to shift in M, because YOU are in charge of deciding shift points. That one wasn't rocket science.
This part of the post was interesting. Faster drag strip times in Auto than in Manual confirms that the car is indeed smarter and faster than we are.
