Almost out of warranty!
hey guys,
Just picked up a 2011 C63 Affaltarbach edition.
the extended dealer warranty (only power train let at this point) is about to run out in about 2 months. Im having them look at my leaky differential and upper oil pan to see if they will cover it (fingers crossed).
What else should i be concerned about before warranty is over. I checked the VIN and its outside of the affected engines with the head bolt issues.
Thanks!
Thanks!
could you get a thorough inspection done on the car by a kick-*** mechanic? I say "could you" because I would have no idea where to go to get one done. Dealer? Independent shop? Which one to trust, etc.? Depending on where you live, you can probably find a recommendation for a shop in your area.
Frankly, my dealer seems to LOVE to find warranty work to do. I would trust them to give it a solid going over, for that express purpose.
i have it booked for a diff seal leak and the upper oil pan is now leaking too :S so hoping those are all covered. also noticing the engine to be a bit louder and rough sounding from within the cabin, but it could just be the sound of it normally (new to AMG).
