C63 AMG (W204) 2008 - 2015
Quick question please help
Old Sep 4, 2017 | 07:09 PM
AMGonFire's Avatar
2012 c63 AMG, 2011 GLK 350, 2019 GLS 450
my car is in the shop with a new diff on order. Was noisy and ended up being bad. It's being covered by aftermarket warranty. My question is this. My car came with factory lsd. How do I know I'm getting the same diff and not the open one. The gears can't just be ordered the whole thing has to be shipped. My mechanic says the dif is linked to my vin. Is this true. Will my vin tell them that it's an lsd and not open diff??? Thanks.
Old Sep 4, 2017 | 07:41 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
It's likely just the ring an pinion getting replaced. The LSD will just get the new ring and everything will be re-assembled with all new parts.
Old Sep 5, 2017 | 12:34 AM
Amr_c63's Avatar
14 polar white E550
I think he means the whole pumpkin is going to be replaced . OP I would make sure to grab the part number off the new diff you are getting and run it by Mercedes and confirm it's the lsd one or just do a Google search .
Old Sep 5, 2017 | 12:49 AM
AMGonFire's Avatar
yea Ill try that. Our diffs the internals cannot be replaced. They don't sell individual parts. The whole unit is getting replaced. 5k cost which is nuts cause you can get aftermarket way cheaper.
Old Sep 5, 2017 | 08:01 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
They can, they just don't sell the individual parts to the public.
Is it not MB doing the work?
Old Sep 5, 2017 | 08:14 AM
AMGonFire's Avatar
my Indy is doing it and if that was true my warranty company would be all over that instead of buying the entire unit with gears in it.
Old Sep 5, 2017 | 08:20 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
If what was true?
Old Sep 5, 2017 | 08:49 AM
AMGonFire's Avatar
If what was true?
being able to get just the gears. Both my Indy and warranty company tried not possible.
Old Sep 5, 2017 | 09:20 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I was referring to MB having access but don't sell them.
A 3rd party can't obtain them but MB does, well at least, did have access to them.
Old Sep 5, 2017 | 10:18 AM
sventastic82's Avatar
2010 C63 AMG RIP. 2021 Toyota Tacoma TRD Off Road, 2013 C63 coupe
Yes individual parts can be replaced, I have replaced every bearing which is probably where the noise is coming from.
To get the parts, research is required on the end the bearings are the same as in a dodge charger, challenger and Chrysler 300. they use the same diff from the Daimler Chrysler days. The rebuild did cost me $250 in parts.
https://mbworld.org/forums/c63-amg-w...n-bearing.html
If you get a new diff make sure you take the old one and sell it.
