is running 255/35/18 on stock wheels okay? any rubbing?
Max width for front and rear on stock rims is 245 for your 8" fronts and 265 for your 9" rears.
http://www.tyresizecalculator.com/ch...rim-size-chart
thank you for the feedback! I might do 245/40 in the front and 275/35 in the rear. I think 275 on the rear should be fine correct?
Will a 275 rub? Maybe yes, maybe no.
Is a 275 tire on a 9" rim 'fine"? No. Read prior post.
Is 245/275 a good mix on a car that already plows? I'll let you figure that one out.
You would be have to be an avid racer to notice any handling or driveability difference as compare to the stock 255.
I noticed 0 difference in my car in the 2.5 years it had 275's as compared to the 255's that were on it.
275's look a hell of a lot better as well
