C63 AMG (W204) 2008 - 2015
High Oil Consumption (0W40 Mobil 1)
Old Oct 3, 2017 | 09:31 PM
NotABaller's Avatar
2012 C63, 2014 E550
Originally Posted by JimGnitecki
Notaballer, if you love the sound that much, do NOT ever drive an Alfa Romeo 4C. You will HAVE to buy it. That was easily to-date the most addictive car I have ever driven. Totally blew me away. But also totally impractical except as a dedicated toy. Almost no trunk space at all (forget even a briefcase), REALLY small interior, awful rearward visibility. But the sound and the handling . . .
Stay away from one of those. It'll seduce you.
Jim G
If that Alfa is as you sound, then I will definitely not drive one... or ride in one, or watch videos of one, or read about one... ooops
Old Oct 4, 2017 | 12:49 PM
13pp63's Avatar
E63s
I use liquid molly 5-40 I belive or dealer oil when it's there it's there now for same
thing oil consumption they say it's normal
if driving hard but still under warrenty there replacing plugs that look bad, oil air separator, 4000 k since last oil change and my cars just above the min level so right before the light comes on. I'll know Ina few hours exactly what else is being done. Leak down test is a good start for sure mine was done and passed with flying colours thank god.
Old Oct 5, 2017 | 06:17 PM
NotABaller's Avatar
2012 C63, 2014 E550
Someone told me i was burning oil on the highway. Pulled alongside me and told me he's seeing blue smoke in exhaust. This was about one hour after starting car and driving home. About 80-90km/h.
I measured my oil and it's a bit over the top red marker, was probably 2cm over the topmost red tab. Is it ok?
Old Oct 5, 2017 | 06:55 PM
JimGnitecki's Avatar
2012 Mercedes C63 AMG S
Notaballer: 2 centimeters over the high mark is over 3/4 of an inch over the high mark! That's a BIG overfill, and your high rpm driving habits make it even worse. Too much overfill can actually create oil leaks where none existed before, can cause the oil to run hot (didn't you recently report THAT too as a problem on another thread?), and can cause enough oil churning to get oil into the combustion chamber.
Get your oil level management under proper control. ONCE you have done THAT, THEN repeat the test of the observer watching for oil smoke while you cruise. If you still have the oil smoke then, you have a different, more serious problem (e.g. worn valve guides, or worn piston rings)
Jim G
Old Oct 5, 2017 | 07:00 PM
NotABaller's Avatar
2012 C63, 2014 E550
Jim G
Thanks Mr. G (I like this name),
I knew I overfilled a bit. I guestimated that it was 0.5L extra, from the amount left in the Mobil 1 jug used to fill up. I think its not 2 cm, but much closer to 1. In any case, I thought it was okay since its only a marginal overfill of less than 10%. Surely our engines experience similar conditions when we go up a hill or something that causes the oil to gravitate to a specific side. Perhaps it was a bit too much and overcomplicated things. Also, potentially introduced new points of failure and unnecessary risk. God thing I have a mityvac - will mityvac out some excess oil tonight and report back after I get someone else to drive/test my car.
Old Oct 5, 2017 | 07:09 PM
Thanks Mr. G (I like that name),
I get that a lot. Seems that it is very difficult in the English language to say "Gnitecki" (no vowel between the "G" and the "n").I most often hear "Jim G".My wife has THREE versions for different situations:
"Honey" for when I am behaving
"Dog" for when I am somewhat misbehaving
"Pig" for when I really **** her off
The advantage of a difficult surname is that it makes it very hard for anyone to use my name in vain.
Old Oct 5, 2017 | 08:02 PM
  #32
604 C63's Avatar
2012 E550 Cabrio
So after you overfilled you carefully avoided all hills and things that cause the oil to gravitate to a specific side? Since that margin for error had already been used up?
Old Oct 5, 2017 | 09:10 PM
  #33
NotABaller's Avatar
2012 C63, 2014 E550
Good point. Probably not, and this was on a downhill section. Maybe that had an effect
Old Oct 10, 2017 | 04:29 AM
  #34
kimeran's Avatar
2012 C63 AMG, 1991 325iS. Ex: 2011 C63 P31
I know everybody's oil consumption varies, but I haven't ever had to top up this motor between oil changes.
Ton of city/urban driving, all done like I was a 15 year old who just escaped from Juvenile Custody.
Agreed.
I drove my car quite hard...all the time.
I used to engine brake every single time I needed to slow the car down.
I eventually went 3 months passed my service interval, and raced it a lot in that time. Not once did I need to fill oil, it never went below the full mark at all.
Old Oct 10, 2017 | 11:42 AM
  #35
skratch77's Avatar
2005 E55
I'm the same I drive my car really hard and usually stay in 3rd gear and never really need to add oil.
I'm running 8100 along with mos2
Old Oct 10, 2017 | 11:48 AM
  #36
NotABaller's Avatar
2012 C63, 2014 E550
You are a champion.
It seems a lot of members running Mobil1 0w40 experience roughly similar consumption as me. Shout out to Diabolis and all the other vets here for their great technical contributions in many of the older threads.
Old Dec 4, 2017 | 11:08 AM
  #37
NotABaller's Avatar
2012 C63, 2014 E550
Quick update: Have not had to fill up oil since my last time. Its been 6000-7000KM and still no warning light. I've been driving a lot more calm and with less downshifts/high rpm liftoff. Everytime I downshift to a stoplight above 2k rpm, I can still smell the oil. But I guess that's because I'm almost running no cats.
Old Dec 4, 2017 | 12:40 PM
  #38
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
with Mobil 1 0w-40?
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Dec 4, 2017 | 02:22 PM
  #39
NotABaller's Avatar
2012 C63, 2014 E550
Originally Posted by hachiroku
with Mobil 1 0w-40?
Yes, I havent changed my oil, despite many suggestions from people telling me to go 5w-40.
Old Dec 4, 2017 | 03:22 PM
  #40
hachiroku's Avatar
SPONSOR
yeah...i didn't like Mobil 1...Motul X-Cess 8100 5w-40 with LiquiMoly MoS2 is the honey to wine.
good luck.
__________________
-BARRY
Old Dec 5, 2017 | 02:16 AM
  #41
kimeran's Avatar
I had secondary cat delete, resonator delete, and mufflers delete. Never had the burning oil smell. If that helps.
Old Dec 5, 2017 | 11:20 AM
  #42
NotABaller's Avatar
2012 C63, 2014 E550
Thanks for the info. Do you top up oil between changes? I had deleted secondaries and resonators too, and couldnt smell anything. It was only after headers (which deletes the stock primary cats) that I smelled exhaust fumes at every stoplight and oil smell on high rpm downshifts when coming to a stop.
Old Dec 6, 2017 | 01:49 AM
  #43
kimeran's Avatar
Never had to top up oil, not once.
I never did headers though.
