C63 AMG (W204) 2008 - 2015
P2422 - EVAP System Vent Stuck Closed
Old Nov 27, 2017 | 03:18 PM
royalmathmtcs's Avatar
P31 C63 AMG
Has anyone else dealt with this? My 2010 is throwing this code repeatedly after I've cleared it twice. From a parts standpoint, it seems like I need:I don't have any problems starting up, fuel fills up without problems (I don't top off). I'm guessing that the code is triggered based on the valves closed state. Would I be fine with just replacing the valve, or should I definitely do the canister as well? Are there any other parts I should consider to fix this? Thanks in advance.
Old Jan 15, 2019 | 03:49 PM
BlackDiamondz's Avatar
2005 mercedes c320
What did you do to fix code p0222?
Did you replace the shut off valve and activated???
Old Jan 18, 2019 | 01:51 PM
P31 C63 AMG
The charcoal canister came with a shut-off valve pre-installed when I bought it. It solved the problem.
