Trickle Charging Battery For Storage
In the second pic you put the negative terminal,from your charger, on the copper colored post to very right top side of the strut tower.
The permanent loop hole connection I unscrew the gold bolt put the loop down then re screw for the negative but was unsure which three of the bolts on the terminal cover to use as some has thicker cable running to it than others. I can use eitheir of them 3 bolts to put the positive loophole connection onto then? I may use the middle on as that has the positive blade terminal at the side of it.
Yes when I looked under the hood today I thought wtf its totally different! Strange as the only difference is mine is RHD so ive just used the clips for now and its on the long step 3 charge.
My tuner seems to think its the middle bolt next to the terminal clamp but until I visit them again in the future ill leave it for now. I have just read too it only goes onto the trickle charge after its done the float charge (step 7) for 10 days!
Use the one next to the blade for power.
