C63 AMG (W204) 2008 - 2015
Retrofit Genuine Reverse Camera
Old Nov 25, 2020 | 09:15 PM
Lucky68's Avatar
2009 S63 AMG, 2005 E500, 2005 C240
Unhappy
Does this only apply to the vehicles with COMAND? I have a 2013 C300 with the Audio 20 radio. I've been in the Engineering menu and I do not see an option to enable a camera. Has anyone added a backup camera to an Audio 20 radio?
Old Feb 11, 2026 | 06:51 PM
Mjk999's Avatar
2013 C63 AMG, 2013 E63 AMG, 2004 Lexus LS430
Question about installing aftermarket camera to OEM harness.
What's up man. So I have a 2013 c63 that has an OEM back up camera already but I want to install the aftermarket one that is mounted next to the trunk handle.
The reason I want to switch to this camera is because it is a lot better of a picture and does not show the rear bumper at all. My friend installed this same camera on his 2923 c63 that didn't come either OEM back up camera.
I wanted to know if I can just cut the wire and connector off OEM camera and splice it into RCA cables on aftermarket camera.
The conne cut it in my hand is the one I'd be cutting off to splice in new camera.
The connector/wire in my hand is on the OEM camera which is the one I'd be cutting off to splice in new camera.
Please feel free to send me a message on here or on Instagram @ xMJK999x to help explain it more.
here is the link to the camera id like to install.
https://ebay.us/m/lpo6AW
Old Feb 11, 2026 | 06:58 PM
Mjk999's Avatar
So do I just need to splice the RCA cables to the factory connector like the last pic you posted?
if so could you explain which wires need to be spliced together?
Attachment 415382[/QUOTE]
