What The!!?!!
What The!!?!!
So I was at the store this morning and I put the bags in the trunk (opened normally) but when I went to start the car it fired and immediately died. All of the dash lights were on but no CEL. I pressed on the brake again and it fired up as it has always done but the brake pedal went further down than usual once it started. After that the brake pedal worked fine as did everything else. Drove home with no incidents and parked it in the garage. I let it sit a few minutes and tried to start it again. Fired right up. Now I've read on this site of issues with the C63 not starting but from what I recall they didn't even turn over. The cause was the steering column and a switch located within (I believe). In my situation I'm wondering if:
1. The battery in the key fob is weak.
2. I was being a dork and took my foot off the brake too soon.
3. This is the harbinger of a bigger issue.
Anyway, If anyone has had this issue and/or can give me suggestions as to what it may be I'd be most grateful. My 2013 C63 has a little over 22k miles and I've always followed the service schedule, the last being in November 2017 when it was given a clean bill of health.
#2 more than likely
Thanks SaphGreyC63 and curt.r for your responses. I truly hope this is it (being a dork). Even so I did replaced the key fob battery just to be safe.
SaphGreyC63 (01-24-2018)
