C63 AMG (W204) 2008 - 2015
Lean code issue 2009
Old Apr 5, 2018 | 08:28 PM
scrappykoko63's Avatar
c63
This is the specs from the codes.
took my car to mercedes been there for a month they replaced my gasket inside the intake manifold and im still getting codes p0171 and 174 they said they did do the smoke test but the gasket was the only issue. The car idles a little under 1k and at 1 when i drive hard, sometimes it shakes on idle and shakes alot more when i clear the code and turn on the car. Ive had this issue on my c63 for about three months now please help
Old Apr 5, 2018 | 11:00 PM
Amr_c63's Avatar
14 polar white E550
Definitely was the same symptoms I had when my intake gaskets failed , did they replace the pcv valve also when they did the job ?
Maybe the manifold is cracked itself ? Best way to self diagnose this is with the engine running spray some carb cleaning around the intake manifold by where the gaskets are and if the idle raises you know where the issue is .
Old Apr 6, 2018 | 07:26 AM
Celicasaur's Avatar
W212 - E63 AMG
If there aren't any more vac leaks, then there's a chance that the throttle bodies might be the issue, inside the manifold unit.
The butterfly plates should have a teeny bit of free-play, so that when you poke them with your finger, you'll be sealing them flat/shut. if one/both of them can't go backwards (probably like...1-2mm of movement) to seal the opening around the perimeter of the bore, it will trip a lean code, rough idling and all sorts of issues that don't make any sense if you are unaware of this.
Ask me how I know
Old Apr 6, 2018 | 09:34 PM
c63
Guys so i cleared those codes and then when i turned on the car it went into limp mode my fixd device said its cylinder 5 misfiring.. Wtf is going on with my car!?!? The dealership said there was no more leak i dont know what to do anymore
Old Apr 7, 2018 | 06:59 AM
Celicasaur's Avatar
W212 - E63 AMG
....pull the coil from 5 and the plug also for a visual. Then swap 5 with 6 and see what the code tells you when it comes back.
Old Apr 7, 2018 | 07:26 AM
c63
could the idle and lean codes just be from the misfiring???? Or is there still a leak somewhere in there.
Old Apr 7, 2018 | 08:23 AM
Celicasaur's Avatar
W212 - E63 AMG
I have no idea, but I've already advised on what else I think could be the issue regarding an internal air leak. However now that you're saying you've got a mis-fire and on cylinder 5, taking a look at what causes the spark on cylinder 5 would be the next logical step to take. There's only so much somebody can advise on a forum....you'll need to get the tools out and investigate/report back if you want to solve this.
