ESS Supercharger DIY Installation
Oh well, I will never use the performance over 6000 rpms except for an occasional run at the drag strip, and the car now runs so great and is so powerful I will most likely not spend the money or effort to see where my last 40 hp is hiding over 6000 rpms, but EES is sure curious and will re-dyno my car if I make any changes. My guess is that the Cats are the main offenders but I don't want to make the car any louder than it is now and also that is the much more expensive route to go.
I want to thank everyone for your help and comments during my installation project, and feel free to ask me any questions as I am more than willing to help others who may be doing their own installation
Jim
My 2012 with low boost pulley and 91 octane
EES 2009 Euro spec with low boost pulley and 91 octane
Great to read, Jim. It’s always nice to see a big mod working out so smooth. Those are very good numbers! Also good to see a different project apart from Weistec’s SCs (nothing against them, BTW). Hopefully you’re having a blast. Try it out on the drag race to let us know how are your tires handling this new setup.
Kind regards,
V.
intercooler I had to replace
I did have a problem about 3 months ago where I noticed white smoke in my exhaust and the intercooler radiator in the supercharger had developed a pinhole leak. This allowed the antifreeze in the SC system to be blown into the engine. It was a small amount so it didn't do any other damage. You can change the small radiator in the SC by removing the top SC lid, and ESS gave me a new radiator that solved the problem. Otherwise I haven't done any other tunes or modifications as it still scares me when I really get on the throttle during street driving. A new grandchild has taken up a lot of time so I never got it over to the local drag strip before the 110 degree weather started in Phoenix. But I can say it never overheats with the SC during street driving and the AC still gets the car cold. The engine temps stay the same as they were prior to the SC.
Can I ask you what you did for the return line on the passenger side of the sc coolant radiator?
According to the instructions, you're supposed to use the long steel reinforced tube to return back to (wherever it goes, I can't remember) but there was no way that hose would go in the desired path or any for that matter. My super awesome mechanic decided to go with a high quality heater hose and it worked, no kinks or bends in the line either.
Also, are you running stock plugs?
This is the hose that came with the SC kit.
Otherwise the blower works. Good luck everyone.
So far so good. No leaks, below 2k rpm, there really is nothing to indicate that there is anything else going on with the car other than a slight rumble and the whirr of the supercharger.
On the Agency Power headers: above 3k RPM, the headers make themselves known. I would estimate 50% louder than stock. I haven't tried WOT yet because the car is scary. Scary fast, scary loud.
I am considering putting HFC behind the headers and installing the secondary cats back in place as it is a catless setup at the moment. Loud and stinky. Cold starts are nuts.
On the ECE motor mounts: there is a slight vibration that travels through the car, not annoying and it goes away above 1k rpm, other than that, the motor mounts are solid.
I also have a weistec catch can and UPD underdrive pulleys (since the factory plastic ones tend to let go when you start making power)
More on this as I drive it.
Upon starting the car, check engine light.
Now, it had been sitting for about a week (give or take a day) due to cold weather, and it was a particularly loud start. Look down, engine light.
It was a cylinder misfire (which was easily cleared) I wonder if it was a combination of the old gas and sitting around for awhile?.
Someone suggested using 94 oct gas which has an ethanol blend which I am not sure how it would behave with the S/C? My mechanic suggested perhaps colder plugs might work better too since we're in a colder climate?.
Been driving it for another day and it hasn't been throwing any more codes either (also filled the tank with fresh 91)
Thanks, Mike
but I guess I'll just change it every three fuel ups.
