C63 AMG (W204) 2008 - 2015
Sds star tweak thread
Old May 13, 2018 | 01:42 PM
skratch77's Avatar
2005 E55
Can we start a thread of what we can do in sds for our cars?.
I'm about to mess with it and my goal is to get it to run the oil cooler fan sooner and run the big engine fan sooner.
also would like to disable the seat belt chime.
anyone have any info on either?
Old May 13, 2018 | 02:59 PM
AMG3.2's Avatar
C63 AMG, P30
This would be awesome. I used to do this stuff with my E46 M3 since that community is extremely active in terms of coding, etc. I've searched, but can't find anything relating to coding within SDS and I'd love to be able to do the same with my C63.
Old May 13, 2018 | 04:06 PM
Phil_T's Avatar
C63 AMG Saloon
Where did you buy sds from?
Old May 13, 2018 | 05:26 PM
skratch77's Avatar
2005 E55
I bought it off ebay
Old May 13, 2018 | 09:37 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
I think Funkwagen should be able to help out.
Old May 15, 2018 | 01:34 PM
xEryx's Avatar
2019 E63s AMG
I've done the following changes:
Update 2012 HU color to 2013
Update 2012 Dash color to 2013
Passenger seat belt chime removed.
DRL brightness adjustment.
C LED ON at all times.
Light switch adjustment.
Transmission adaptation disabled.
Speed limit 186mph
Reverse limit 40mph
I want to do:
Flashing brake light on hard braking.
Auto close all windows when holding circulate
Auto close sunroof when rain detected.
Transmission software update
Some others I might be forgetting.
I got some ideas from here http://www.slkworld.com/das-star-cod...as-tweaks.html
Old Mar 6, 2019 | 11:27 AM
561design's Avatar
2014 VW Touareg, 2012 C63
Any more updates on this topic? I've found a ton of stuff for w211 but not sure what's available for our cars.
Old Mar 6, 2019 | 12:06 PM
SaphGreyC63's Avatar
2012 C63 AMG Sedan
Speed limit 186mph
Reverse limit 40mph
I want to do:
What exactly do we need to do to get this done? I am particularly interested in the first 2 lines, the 2012 to 2013 Dash color change.
Based on everything I've read before I was told it just plain, cannot be done.
Old Mar 6, 2019 | 01:24 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Interested in this also. Need to find someone in SoCal to turn off all the warnings for everything I’ve removed (airbags etc).
Old Mar 6, 2019 | 01:35 PM
2012 C63 AMG Sedan
Wait, have you always been in SoCal?
Old Mar 6, 2019 | 01:41 PM
BLKROKT's Avatar
And the flashing rear brake light would be awesome. More info here: https://mbworld.org/forums/s-class-w...ml#post6031544
Nope. Just moved out here in Dec. Was in NYC.
Old Mar 6, 2019 | 01:43 PM
Funkwagen's Avatar
2009 C63 AMG, 2010 C250 4Matic Sport
At some point I'll sit down and try to remember everything I've changed about both of my cars, with screenshots of the parameters and everything. I've not touched flashing modules much after nearly bricking my instrument cluster, though. Just variant coding
Old Mar 6, 2019 | 02:04 PM
561design's Avatar
lol, I pulled my seats to paint the backs and I got that warning. Hopefully it goes away when I plug the seats back in.
Old Mar 7, 2019 | 01:39 PM
Mort's Avatar
Should have disconnected the battery before before disconnecting any SRS component. Now you will need Xentry to reset the codes and warnings.
Old Mar 7, 2019 | 04:09 PM
MBNRG's Avatar
561Design - if no access to Xentry, can reset/erase SRS error codes (after connecting all necessary SRS harnesses) with certain OBD Scanner apps like Carly for Mercedes (worked very well for me).
Old Mar 7, 2019 | 11:44 PM
561design's Avatar
Yes, I didn't want to blank out my air ride settings though. I have a merc diesel mechanic friend that has agreed to reset the codes for me. More because he wants a sneak peek of the car in person.
