C63 AMG (W204) 2008 - 2015
Hitting the Dragstrip tonight (Ccecil Co MD), Couple Questions
Old May 25, 2018 | 12:52 PM
Boughtittwice's Avatar
'21 GT4, ‘11 C63 P31, ‘04 VW .:R32, '88 Chrysler Conquest TSi, ‘15 Ram Longhorn, '
Have a couple quick questions since this is the first time I am running a C63, used to run my W204 E55 quite regularly stock, 12.2s. Setup currently on the C is as follows - stock, with new PS4s on stock 18"s (265 in the rear).
Lowering PSI to 25lbs. in the rear, is that an optimal pressure?
Any benefit to cooling the intake with an ice bag between runs? Weather will be low 80s/Upper 70s, low humidity.
Thanks...
Old May 25, 2018 | 04:25 PM
skratch77's Avatar
2005 E55
I do a burn out then turn traction control back on and use m mode and shift right before redline.
Old May 25, 2018 | 05:24 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Don’t go through the water obviously. Dry burnout. Brake boost to 2500rpm and drop it.
Old May 29, 2018 | 09:45 AM
Thx guys...
Best run of the night was my first pass - 12.2 @114.. the rest ended up 12.4-5s - no ice in between. Need to get better at launching, best 60' was 1.9...
Old May 29, 2018 | 10:45 AM
East Coast Euro's Avatar
Former Vendor of MBWorld
C63 and CLK55
Nice runs! 60' comes with practice. Hopefully run into each other at the track some day
