C63 AMG (W204) 2008 - 2015
P30 Front break discs
Old May 28, 2018 | 01:41 PM
sander.manzoli's Avatar
C63 AMG 2012 Sedan
I own a P30 2012 C63 AMG and I need to change the front discs.
Are these discs the same of a regular (non-P30) version?
Thanks a lot!
Old May 28, 2018 | 02:08 PM
C63 AMG 2012 Sedan
No, not the same... but a regular one will fit:
https://mbworld.org/forums/c63-amg-w...-pads-p30.html
Old May 28, 2018 | 02:40 PM
toosteeley's Avatar
Present: 2019 C43 Estate
Where are you located? I'm selling a complete set of rotors & pads from a 507 edition with only 10,000 miles on them if you're interested.
Old May 28, 2018 | 03:30 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Thanks a lot!
Not the same, the P30/P31 units are a little lighter and most people call them 1.5 piece rotors as they are not true 2 piece rotors. If it was my money, would just get the regular C63 rotors, fit right on, a little bit heavier (although not much) and are like $150 each instead of 800 each and you probably can't tell the difference, maybe if you track the car.
Old May 28, 2018 | 03:59 PM
C63 AMG 2012 Sedan
I´m in Brazil... I´ll go with regular non P30, and I don´t need the rear ones, thanks!
Old May 28, 2018 | 06:25 PM
AMG3.2's Avatar
C63 AMG, P30
Just FYI to avoid confusion -- P30 are true two piece, P31 are one piece floating.
P30:
P31:
Old May 28, 2018 | 07:11 PM
Top Answer: 1
I wrote it like that as he said P30 but has a 2012 so a P31 car, but yes as AMG3.2 shows above, the early P30 cars had the real 2 piece instead of the 1.5 piece cheaper units of the later cars. (cheaper as in make not the price they charge you for them!)
Old May 29, 2018 | 12:56 PM
C63 AMG 2012 Sedan
I actually own a P30 2012 model (manufactured and delivered in late 2011). I have my decoded VIN printed. I know later 2012 models are P31.
Old May 29, 2018 | 01:33 PM
Top Answer: 1
they all show as p30 in the vin decode for all years
Old May 29, 2018 | 01:37 PM
C63 AMG 2012 Sedan
Wow, vin codes will show P31 as P30? That´s news to me, thanks for the valuable info!
It means that since I got no LSD code line in my VIN code list (471), and it´s a P31, not P30, I got no LSD? Astonished! Thanks!
Old May 30, 2018 | 02:32 PM
C63 AMG 2012 Sedan
Are Zimmerman discs (400.3660.20 for my car) ok?
Probably not great as the original, but I want to know if they are a valid option (not BAD), since I have them in stock here in my city.
Old May 30, 2018 | 06:41 PM
cm60k's Avatar
"Zimmermann" Rotors are really great, i used them many years with differ models,,
but be sure to use them with OEM pads..
-;ZAYED;-
Old May 30, 2018 | 09:16 PM
Top Answer: 1
Also had good luck with the zimmermans, they are decent quality OEM spec.
Old May 30, 2018 | 10:15 PM
1REDC63's Avatar
2012 C63 AMG
Can you still use the p30 true 2 piece rotors on a facelift p31
I was on eBay and they look to be Brembo at 750 for the pair
Old Jun 1, 2018 | 03:36 PM
ceesixthree's Avatar
2012 C63 AMG Coupe P31 Magnuson Super Charged
Yes I got brembos two piece on my facelift they are fine.
Old Jun 1, 2018 | 09:19 PM
SactownP31's Avatar
C63 p31 coupe, Clk550 cab, M3 coupe, LS430, 750LI
If it was your money. C'mon man, would you seriously put the standard brakes on your car? Doesn't your 507 come with pp brakes.
Old Jun 2, 2018 | 01:38 PM
Top Answer: 1
I would, the 1.5 piece rotors are such a waste of money for almost zero performance gain and hardly even look any different - what I would probably consider would be the bembo p30 2 piece units as they are a fair bit cheaper than the P31 units and actually 2 piece.
Old Jun 2, 2018 | 01:52 PM
AMG3.2's Avatar
C63 AMG, P30
You can also just buy rotor rings from Coleman racing if you have the P30 setup.
Attachment 441148
Old Jun 3, 2018 | 10:31 AM
realjones88's Avatar
2012 C63 P31 sedan
p31 is the mercedes OPTION code
So the p31 option code includes various BUILD codes, which is the P30, 923 (more hp), etc you see in the vin decode.
In the USA the LSD (471) was never included with the P31. It was always a stand alone option. Not sure about Brazil.
