Crappy predicament - thoughts?
C63 AMG, P30
Hi all,
Cliffs notes: Shipping car to Austin, TX on Tuesday morning, broke the vent tube attachment to my thermostat, and coolant leaked everywhere making the car non-drive-able for more than 30 to 45 seconds at a time on a cold engine.
It connects here:
The car is shipping in an enclosed trailer and I plan to tell the driver to keep the car on for 30 to 45 seconds at a time max should they need to move it, but I'm still somewhat worried.
Should I use some sort of crappy mighty putty or something to create an end cap on the thermostat vent piece that I broke (I'll replace it when I get to TX), and also attempt to cap the line that attached to the broken end piece? Doing this would essentially block off the vent/breather part of the thermostat.
Image from thermostat (white stuff is some putty that I was already debating the idea with)
Any down sides of doing this as a safety precaution just for the move so the car can at least hold coolant?
Thanks for any help in advance.
It connects here:
In an emergency situation, I'd find a screw that fits in the broken piece. Wrap screw with teflon tape and screw it in. You would be dealing with around 16psi or so, car would be movable.
C63 AMG, P30
And how would you cap this piece?
Edit: I'm going to slip some hose over it (hose clamp it) and cap that end with a teflon coated screw.
Attachment 441139
Remove the pressure cap from the header tank so that the "repair" is not under pressure. As long as the repair doesn't leak, you can run the engine for hours under light load - just keep an eye on the coolant level.
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
I would also completely remove the thermostat from the housing (i.e. allow the coolant to freely circulate from the moment you start the car) and make sure that there is enough coolant in there... you don't want to end up with warped heads or a cracked block.
Alternatively, completely disconnect the battery and have them push or winch the car on and off the trailer.
Received 2,810 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
JB Weld that. I wouldn’t chance the shipping company to even be able to start the car. You don’t know if whatever repair you make will hold. I would tell them the car is disabled, then disable it yourself by removing the battery. You can’t trust other people with this kind of thing, especially when that means that your engine will be destroyed if a variety of chance things happen along the way. They should be prepared to deal with a non-starting car, and make sure they have whatever is needed to do so.
C63 AMG, P30
C63 AMG, P30
$150 for them to push the car onto the liftgate since the lovely business does not have a winch...
I'm going to keep the battery attached so we can remove the key when shifting between P and N, but remove the starter fuse. Thanks for the ideas everyone.
C63 AMG, P30
I just don't have the bandwidth to swap it out tonight unfortunately. Plus, I'm thinking that all of these small plastics in the area must be so brittle that if I tap anything incorrectly, I'll break something else, and won't have that margin for error. (Go back to dealership in the morning to get said hose fitting or something)
AMG3.2 (06-04-2018)
