C63 AMG (W204) 2008 - 2015
P2097
Old Jun 18, 2018 | 09:47 PM
SactownP31's Avatar
C63 p31 coupe, Clk550 cab, M3 coupe, LS430, 750LI
P2097
Sup fellas, lately I've been getting a CEL. P2097 is the culprit. Ive tried searching but nothing on that specific code. I've erased code twice and it stays off for about 200-300 miles. I noticed it started doing it when I drive the car in C, like a little bi.... Car has arh catted lth with cheapish post o2 spacers and EC V7 tune with rear o2 left on. Do you guys think its tune related or should I get better o2 spacers, probably some honeycomb ones. Want to get this sorted out before I install EC Flex Fuel Kit with 550cc injectors. As always thanks in advance.
Old Jun 18, 2018 | 10:28 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Generic code means
P2097 – Post catalytic converter fuel trim (FT), bank 1 – too rich
so bad O2, oil fouled O2 or maybe your spacers like you said but O2 appears to be reporting too much fuel post cat.
my 335i throws the same code with the high flow cats if not suppressed.
Old Jun 18, 2018 | 10:40 PM
SactownP31's Avatar
Originally Posted by roadkillrob
Generic code means
Thanks. I'll try better spacers that act like mini cats. Then I'll try new new o2s if that doesnt work.
Old Jun 18, 2018 | 10:58 PM
skratch77's Avatar
2005 E55
Are you running extension wires on the rear o2s?
Old Jun 18, 2018 | 11:04 PM
SactownP31's Avatar
Yeah, the ones supplied in the ARH kit.
Old Jun 18, 2018 | 11:12 PM
skratch77's Avatar
2005 E55
you will never pass with wire extensions. I have been there and done that.
need to have bungs welded close enough to not need longer wires and you will pass even with no cats using o2 spacers.
Old Jun 18, 2018 | 11:20 PM
SactownP31's Avatar
No shyt, so its the extension that are causing the CEL? Good to know.
