C63 AMG (W204) 2008 - 2015
Caliper Brackets for Black Series Brake Rotors On Stock Calipers
Old Jun 19, 2018 | 05:38 PM
MBNRG's Avatar
Arrow Caliper Brackets for Black Series Brake Rotors On Stock Calipers
Step up to larger Black Series size 390mm brakes on the C63 W204:
THESE BRACKETS WORKS DIRECTLY WITH YOUR STOCK C63 FRONT CALIPERS (NO NEED TO CHANGE CALIPERS)
Simply install these brackets to your existing stock front calipers - they will push out the calipers to accommodate the larger Black Series sized 390mm rotor (which you will need to purchase separately). Stock C63 front rotor is only 360mm.
For your consideration:
Pair of New RacingBrake (Racing Brake) Front Brake Caliper Brackets to accommodate the larger 390mm Black Series front rotor.
Includes New Hardware (4 Bolts and 4 Washers) to attach these Brackets to your Stock C63 Front Calipers.
These RB Brackets will work with OEM Black Series 390mm Rotors, as well as the Racing Brake 390mm Rotors.
They have been mounted to verify fitment:
Will fit the OEM AMG 19" wheels and most 19" Aftermarket wheels.
Will NOT fit the OEM 507 19" Wheels due to a taper in the 507 wheel barrel.
Multiple individuals are successfully running and tracking with these same brackets.
These brackets are NOT sold separately by RacingBrake.
Asking an even $500 with shipping to CONUS
Old Jun 19, 2018 | 05:54 PM
SuckaGDog's Avatar
C63 AMG Black Series
How many threads are you going to make for these?
Old Jun 19, 2018 | 05:57 PM
MBNRG's Avatar
Thread gets moved. This may help someone looking for this upgrade, and will help me sell them
Thanks for your helpful feedback.
Old Jun 22, 2018 | 06:15 PM
MBNRG's Avatar
Old Jun 27, 2018 | 07:08 PM
MBNRG's Avatar
Old Jul 22, 2018 | 05:18 PM
MBNRG's Avatar
SOLD
Thank you, Dale Ross - a gentleman and fellow enthusiast!
