VRP M156 Intake spacers
How have you guys addressed this issue ?.
Ours are not the same height as UPD, No gap.
Sound familiar.
Just Like the oil catch can fittings where the one which goes on the intake manifold doesn’t allow you to properly connect the air intake assembly.
Copied not tested!!!
If you trim about 1/2 inch off the clip for the Intake Y it slides right by the Fitting. Been done by 100 People already without issue. This is the solution for your issue. and as designed.
Well.... No one makes fittings this way, so not sure how we could have copied something that doesn't exist...
Weistec makes them.
In case you Never heard of Weistec https://www.weistec.com/oil-air-separator-system.html
Why was no solution given when I emailed about the issue with detailed pictures? The response was that you never encountered that problem.
But now it’s designed that way.
Bad design if I have to shave off a clip which is meant to keep a air intake tight.
And it does collect a lot of oil..... and MB says it's normal for our engines...
Weistec makes them.
The remaining potion of the clip Creates a full and tight seal.
