2012 c63 LSD help
2012 C63 AMG Coupe P31 Magnuson Super Charged
2012 c63 LSD help
Hi,
Does anyone know if a 2012 c63 coupe OEM LSD will fit a 2008 c63 or is the diff different?
Also what ratio it is supposed to be?
Thanks for the help.
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
Aftermarket LSDs fit all W204 C63 models (and there was someone on here that put in an aftermarket LSD in a car that was already equipped with an OEM LSD which he didn't know about), so the first answer is almost definitely yes. As for the second, what do you mean by ratio? Final drive axle ratio? LSD lock-up ratio (percentage)? LSD ramp angles?
Thanks for your reply, I figured out that it would fit like you said. I am just selling my oem one and someone wanted to know the drive ratio of the diff like 4:1 for example. Just couldn't find a spec
Final Drive (ratio) will likely be stamped on differential carrier and/or diff's ring gear, check pics in thread below:
https://mbworld.org/forums/c63-amg-w...e-changer.html
Many report Final Drive for W204 C63 is 2.82 as Mort noted above, however, there are a few who report they have 3.06
Let us know what your Final Drive ratio is on your OEM LSD setup
