Rattle on startup
It drives absolutely fine apart from the annoying noise when I crank it.
If it is indeed the cam adjusters, how would you know which one to change, or would all 4 have to be replaced?
Would it be a good idea to replace the headbolts at the same time seeing as the cams are out?
Are there people who have driven with this noise with no problems?
The last oil change was done in January by the dealer using Mobil 1 5w30 229.5
cam adjuster. I have that sound on my car for 3 plus years. No I’ll effects or performance issues at all. If you look through the forum no one has found a fix for the sound. Pretty sure it is a poor design and oil bleed down is the culprit. I had my adjusters replaced did nothing. My top end looks flawless. Honestly I would suggest to ignore it. Read through threads you will see a theme.
