C63 AMG (W204) 2008 - 2015
Stereo connect capabilities
Old Jul 14, 2018 | 06:55 PM
EMTHED's Avatar
09 C63 AMG
Hi everyone. First post so bare with me.. Just bought a 09 AMG.. 100k KMS.. got everything paired with my phone, unfortunately won't play any of my phones music, the car came with the MB connect cables in the glove box for the 3mm wire to head set jack on phone... I'm assuming there is no other way besides changing the cars head unit to run wireless???
Old Jul 14, 2018 | 08:16 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
I believe the pre facelift cars can only use bluetooth for phone calls not for music streaming, for music you have to connect the phone to the cable.
The work around to this is something like the tune2air (bovee) device or other devices that plug into the cable in the glovebox and then you can pair to the device and stream via bluetooth.
Amazon Amazon
https://www.viseeousa.com/products/m...SABEgL68vD_BwE
Old Jul 15, 2018 | 12:37 AM
bhamg's Avatar
C63 AMG
If you use the jack music will sound noticeably better than with bluetooth but your phone will be in continual discharge
Old Jul 16, 2018 | 09:52 AM
D3-AMG's Avatar
1993 Competition Yellow Mica Mazda RX-7 and 2009 C63
I have an '09 as well. If you don't have the iPod kit with older 30-pin connector, then you can only use the 3mm jack. If you get the iPod kit, you can buy Tune2Air, a bluetooth adapter powered by the 30-pin connector. It works well but has some syncing issues from time to time. This morning I had to go into my Settings -> Bluetooth and tap on the Tune2Air to get it to "wake up" and connect. I usually do "random play" but sometimes that reverts to doing "alphabetical play" and the only solution is to go into iTunes and manually set the random song selection.
Old Jul 16, 2018 | 02:39 PM
EMTHED's Avatar
09 C63 AMG
Thanks everyone!!! I think I can live with the wire!! And like mentioned, the sound quality is probably better anyway?...
