Does turning traction OFF also turn off stability control?
When I hold traction button for a few secs, I get the OFF light.
Then I can do burnouts, drifts, donuts etc.
Is ESC also turned off? Never tried/dont know how to activate ESC.
It should be in the manual. Sport (just one click) raises the limit of wheelspin and slip allowed. Nothing is fully off. Holding it for a few seconds turns off traction and stability control fully...until the car detects ABS engagement. And then everything is back on until the event it detects is over. Not sure if that is when you pick the throttle back up or ABS is no longer engaging.
Its been a while but I am pretty sure you press it down it says tc off then you keep it pressed down then it says it turns off the other too but forget what merc calls it. It definitely turns two things off including tc if you keep it pressed.
