C63 AMG (W204) 2008 - 2015
Wavetrac LSD ...
Old Sep 8, 2018 | 05:47 AM
63 Molar's Avatar
C63 AMG
Wavetrac LSD ...
Hey guys
Over the last 6 months since i had the wavetrac installed, i have noticed some "clunking" toward the rear of the car when driving, especially when coming off acceleration and the car changes up a gear ... Should this be of concern ?
The diff feels or sounds a little "sloppy" as such ...
There were no shims placed on the upgrade from OEM ....
Should I take it back to the independent and get him to re-examine ?
Many thanks
Matthew
Old Sep 8, 2018 | 10:26 AM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Yes, of course if you notice something funny you should take it back to the indy that did it versus having keyboard warriors give you every wild guess in the book sight unseen.
Honestly, I don’t know how some of you get through life
Old Sep 8, 2018 | 11:00 AM
Doc Oc's Avatar
2013 c63 amg dev pack
Does it ever happen on sharp, slow turns ? A limited slip can be noisy if you're not using a fluid with friction modifiers but if that was the case you'd hear it on low speed turns right away. Especially when cold.
Also, did the installer check the lash? Do you know what it was?
Old Sep 8, 2018 | 11:08 AM
chrisridebike8's Avatar
'10 C63
helical LSDs do not need friction modifiers. Wavetrac’s site actually says not to use fluid with friction modifiers.
Old Sep 8, 2018 | 11:17 AM
Doc Oc's Avatar
Funny, I just googled that very thing and was coming back to change my post Learned something new today!
Old Sep 8, 2018 | 12:04 PM
Funkwagen's Avatar
2009 C63 AMG, 2010 C250 4Matic Sport
Yes you should have it reinspected. this is the result of an install with no shims or preload adjustment, 18,000km later. edit: to clarify there were no real symptoms until the last 1000km, where the diff started screaming between 70-80kmh and 120-130km/h, followed the next day by a new humming noise and tons of vibration. The wavetrac unit itself was unharmed, somehow the ring and pinion gears were also undamaged
remainder of pinion gear bearing
bearing race of one of the carrier bearings
Old Sep 8, 2018 | 12:59 PM
bhamg's Avatar
C63 AMG
Mine has never clunked from day one, years ago. Also, what fluid are you using? I recommend the better of the two Motul fluids recommended by Wavetrac. Changed it out at 10k miles and consider the new fill a lifetime fluid.
Old Aug 24, 2024 | 03:29 AM
SmithyWings's Avatar
C63 AMG
Originally Posted by 63 Molar
Hey guys
Many thanks
Matthew
Hi Matthew,
I’m just wondering did you ever find out what was wrong with your Wavetrac diff? I too recently got one installed and I’m having similar symptoms to you? I’m reading mixed reviews from people with no noise and some with noise like yours and mine. I also get it when I put it into reverse.
Old Aug 31, 2024 | 05:43 AM
dattorob's Avatar
AMG C63 W204
i have one in my C63, and i do not even notice it regarding noise or vibration, what i did notice after install is improved traction and more
predictable handling when things get slippery. Should be standard on a car like this.
Old Aug 31, 2024 | 10:59 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
If it's clunky the installer likely didn't take the time to set backlash within spec. I've had mine since 2012 without clunks.
Daily driven from 2012 to 2020 using 75W90 Motul Gear 300 recommended by Wavetrac. 2020 to now being track only abuse I switched to 75W140 Motul Gear Competition also recommended by Wavetrac.
