Help in Ohio
2009 C300 Sport
Help in Ohio
I'm looking at a used 2013 C63 in Wooster, OH and I'm several hours away. Is anyone local who could check out and test drive the car for me?
Mike
Mike
![](https://mbworld.org/forums/images/ranks/veteran_marine_corp.png)
Mike,
Although in the past MBWorld members have done this as a courtesy, it really should be you that test drives this car. I personally would appreciate a fellow member checking it out.
But you should drive it for yourself. I would make the time, and see the car for yourself. As only you can decide if this is the car for you or not. That's my $.02!
I think he wants someone to check it out and see if it's worth his time to go look at it. If the first person says the car is crap, then he won't make the trek. When I bought my Lexus back in 2006, it was in the same college town where my best friend from high school was living (a gearhead also), so I had him check it out. Prior to buying, I took it for a spin, but I had him check it out like I would prior to me driving a long distance.
