C63 AMG (W204) 2008 - 2015
Tyres
Old Nov 2, 2018 | 12:37 AM
eashwar63's Avatar
C63 AMG SEDAN 2013 (PP)
Tyres
Hi guys,I want to change my rear tires from 255/30/19 to 255/35/19 since the 255/30 is unavailable in all Tyre brands in my country....Will this change effect my cars speed,handling and stability ?I mainly drive it in streets but do hit high speeds up to 260 kph on the highways.
Old Nov 2, 2018 | 08:34 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
That's roughly 4% larger in diameter. What size are your current fronts? If exactly OEM diameter it could possibly freak out the ESP system. I think someone looked it up and 3% differential is max.
Old Nov 2, 2018 | 10:10 AM
eashwar63's Avatar
Fronts are 235/35 zr19.... Stock came with Yokohama Advan v103.....I can get Yokohama V105 in 255/35/19.....Should I go for it?
Old Nov 2, 2018 | 10:14 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
It will probably be fine for ESP. But your speedo will be off by 4%
Old Nov 2, 2018 | 10:24 AM
eashwar63's Avatar
Will rub to the inside fender in bumps?
