Costco Gas, Lifter ticking
You mention you had your oil changed. What oil and weight was put in? if it's 5W-30, get it changed to 5W-40 or 0W-40 IMMEDITEALY. your oil change is more likely the cause of the lifter tick if it's the wrong weight.
also...be aware most of the time its cam adjuster noise not lifter tick. aside from replacing with new ones you can alleviate through use of different oil/additives. my engine would produce noise often when using Mobil 1, but that is my experience. others may have different outcomes.
