C63 AMG (W204) 2008 - 2015
"Top up coolant" warning
Old Jan 20, 2019 | 07:05 AM
kkkk's Avatar
W204 C63 Estate
I have an early 2010 C63. When I started the car today, the "Top up coolant" warning came on. I immediately turned the car off
Now I have read all about headbolt issues, but I do tend to think the worst in most cases.
I do not think there was any white smoke.
What are my next steps?
Top up the coolant, and see if the message comes back again?
Pressurise the system and see if I can find a leak?
Drop the oil and see if there is any coolant in the oil?
Is the car still safe to drive?
Old Jan 20, 2019 | 09:32 AM
SGM330's Avatar
10' C63
Topping up coolant and doing a pressure test would be the cheapest and easiest options to start off from. Do this first before you drive
Old Jan 23, 2019 | 05:24 AM
kkkk's Avatar
W204 C63 Estate
OK, the coolant has only dropped about 150mL , so we topped it up. Pressure test held 15psi for over an hour
The radiator cap has a slight leak, and the radiator has a minor leak too. Im quite disappointed that I need a new radiator on a 8 year old car.
Old Jan 23, 2019 | 09:21 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
What level will your disappointment be if your HBs fail?
Old Jan 23, 2019 | 11:22 AM
Funkwagen's Avatar
2009 C63 AMG, 2010 C250 4Matic Sport
Be very happy it's just a rad and not a head bolt issue. My heart sunk when I got that warning on my dash, but it was only due to the sudden cold weather. I get this warning every year when there's a significant drop in temperature, in both the C63 and C250. Neither ever really need topping up
Old Jan 23, 2019 | 03:59 PM
skullbox15's Avatar
2014 C63
Seriously! consider yourself lucky.
Old Jan 23, 2019 | 07:16 PM
kkkk's Avatar
W204 C63 Estate
What is the OEM replacement for a radiator? I can get a BEHR Hella radiator. Would this work or should I stick with genuine mercedes?
Old Sep 6, 2019 | 06:58 AM
kkkk's Avatar
W204 C63 Estate
Just got this message again after 4 months. Iv changed the headbolts and new radiator too.
Old Sep 6, 2019 | 12:39 PM
PeterA90's Avatar
c63
If you did the headbolts then that rules that out. Check the entire cooling system. The cars hoses are brittle after tons of heat cycles. Hopefully you used a
genuine Mercedes radiator. Cheap route sometimes costs more in the end.
Old Sep 6, 2019 | 01:27 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Behr is the OE radiator manufacturer
Old Sep 6, 2019 | 02:19 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
kkkk,
For peace of mind, check your oil to ensure that it's only oil and not mixed with engine coolant.
That would rule out broken head bolts, and coolant contamination.
Old Sep 6, 2019 | 03:42 PM
BalanBro's Avatar
2012 C63 P31 Sedan
Originally Posted by Yuille36
kkkk,
True. Send out an oil sample to be analyzed for coolant just to be sure.
Old Sep 6, 2019 | 05:29 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
It's 100x easier to do a combustion leak test. I did this before replacing my headbolts one at a time just to verify the HG wasn't compromised.
Old Sep 6, 2019 | 05:39 PM
kkkk's Avatar
W204 C63 Estate
Is a chemical test like that better than doing a pressure test ?
